Question about Reptile
How to replce the wiring harness on a 92 ford f150
  • 91 Answers
SOURCE: need factory stereo color codes
best way is to get in the with a multireader and find a constant power and a ignition, for the speakers, i use a AA battery with a wire on each end, to test the spekers, you will hear a pop from speaker, so you can find which wires go to what speaker.
Posted on May 06, 2009
emissionwiz
  • 79123 Answers
SOURCE: why does 92 ford F150 4wd stall when shifting it
try this and see if it helps.
, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Posted on Jan 06, 2010
  • 16 Answers
SOURCE: I need the factory wire diagram for 1997 Ford F150 radio
go here shows you all about it http://www.installdr.com/InstallDocs/FLM/PDF/356007.pdf
Posted on Mar 10, 2010
saailer
  • 1871 Answers
SOURCE: i need the exact wire
Hello! Is the vehicle equipped with Premium Sound or just the Base Radio?
Guru......saailer
Posted on Nov 23, 2010
sscullys
  • 984 Answers
SOURCE: I need the wiring diagram
This is the diagram for the fog lamps ( headlamp is a different cell ).
If you are trying to add them to the existing wiring, do not expect the headlamp switch to cab fuse panel wiring to be there ( that is usually what is missing when you can find the fog lamp connectors under the front of the truck ).
File Save as so you can magnify it with the JPEG viewer you use.
Close up of switch
Posted on Jan 28, 2011
Testimonial: "Thanks for the diagram, I'll have a pro install the needed wiring."
Factory stereo system color diagram for 92 ford f150 5.0l 8cyl. truck
1992 Ford F150 Truck Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Aug 19, 2011 | Ford F-150 Cars & Trucks
Im converting a 91 f150 to a 94 f150 and i badly need wiring diag for both vechicles . the harness was chopped lol .
You can get both wire harness diagrams from faxonautoliterature.com. These are Ford dealer manuals so should be correct. You can get them for $40 to $50 for the pair. I've used them before and had excellent service. Hope this helps.
Aug 28, 2010 | Ford F-150 Cars & Trucks
I have a 92 F150 supercab and it wont start...I had someone jump
I would check for spark at the plug wires, and check for fuel, there should be a pressure test port on the fuel injection rail to connect a fuel pressure gauge.
Apr 29, 2010 | 1992 Ford F150 SuperCab
My low speed fan doesnt work on my ford f-150 1995 truck
The blower motor resistor is responsible for blower speeds less than high or full. The resistor is located on the passenger side underdash next to the blower motor, should be 2 screws and a wiring harness, replce the resistor and see if your fans speeds work correctly. Hope this helps, let me know.
Jan 14, 2010 | 1995 Ford F150 Styleside Regular Cab
I need a wiring diagram for an f150 ford radio
Try this website: http://www.installdr.com/Harnesses/Ford-Wiring.pdf
Should have the wiring diagram you are looking for. Good Luck...
Dec 27, 2009 | 1996 Ford F150 Regular Cab
Headlights and running lights work on 92 f150 but turn lamps and brake lights will not come on..all fuses are good. Whats wrong?
If both lights went out at once, you may have to check the wiring harness underneath your steering column and right down under the dashboard. Check for loose or bad wires that need replacing. Check as well the relay if they are still working.
Nov 02, 2009 | 1992 Ford F150 SuperCab
The heater fan on my 1999 f-150 only worked on high,now stopped totally
replce the blower resister,for this is your speeds,,u will find this in the blower box,,,,check blower relay in fuss relay box ,and then check fan switch ,look at back of switch to se if switch is burned if so repair or replace switch plug harness and replace fan switch
Jul 03, 2009 | 2004 Ford F150
Speedometer quit, shifts hard, blows #8 fuse 1992 F150
i doubt it's the buzzer. check the wiring where it goes inside the door first.
Jun 13, 2009 | 1990 Ford F150
Open Questions:
Reptile Logo
88 people viewed this question
Top Reptile Experts
windryder
Level 1 Expert
john h
Are you a Reptile Expert? Answer questions, earn points and help others
