Question about Zephyr Cyclone AK6000 Kitchen Hood
Replace zephyr cyclone light switch
How do I replace the light switch
2 Suggested Answers
SOURCE: replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Posted on Aug 03, 2010
How do I remove burned out light bulbs from zephyr range hood? What do I replace them with?
What model range hood do you have? To remove most of the bulbs from a Zephyr hood, wait for the bulb to cool after use. Then rotate the bulb counter-clockwise about 60 degrees (less than a quarter turn) and the bulb should drop down. If you have problems turning the bulb, try the glass suction cup that comes with the hood or a rubber/latex glove grip. Sometimes a rubber jar grip will also work.
The one way to find out your range hood bulb may be to remove one and look at the side/back. The bulbs are labeled. Otherwise, check your manual. Zephyr has the manuals for most of their ranges here: http://zephyronline.com/customer_support . Use the drop-down menu to select your model.
Different hoods use different bulbs. For AK6500, 6536, 6542 Cyclone hoods, purchase type: 4OR 14 mini flood light bulbs. For the AK2500, 2536 hoods, you need to purchase type GU 10 halogen bulbs. For the Anzio models, including the ZAN-E30AS, get a GU-10 50W halogen bulb.
I hope this helps.
Oct 14, 2011 | Kitchen Ranges
Savona zephyr light switch is burn out.How do i replaced it.
Did you ever find a source for the switch assembly? Janderson@andersonpangia.com
Feb 19, 2011 | Zephyr Savona ZSV-E30AS Stainless Steel...
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
Dripping kitchen exhaust fans
It sounds like there is a restriction in the vent or the hood is to low. It should be at least 18" above the cooking surface.
Jun 24, 2010 | Zephyr Cyclone AK6500 Kitchen Hood
Can I replace the light bulbs without removing the whole panel ?
Yes, it is possible to replace the light bulbs without removing the panel that surrounds the two bulbs. The problem is that those bulbs get slippery because of cooking oil splatters.
I recommend that you use a paper towel and some window cleaner (aka: Windex) Spray the towel and clean the bulb. Let each dry and turn the bulb to loosen it out. Use the moist paper towel to help turn is needed. Be so careful to not break the bulb as you remove it. Good Luck!
Oct 27, 2009 | Zephyr Cyclone AK6500 Kitchen Hood
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
Feb 14, 2009 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Replace fan/light switch zephyr pyramid range hood
Thanks,
Robert
Feb 08, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Replaced light bulbs but no light
Original bulb has a JDR designation. I ordered bulbs and received bulbs with a JDRC designation, the brand was Hikari--these bulbs were shorter than the original bulbs and will not seat properly even after removing filters and turning bulbs by the neck of the bulb (porcelain section). Since they won't seat completely in the socket there is no electrical contact and they won't work.
Feb 05, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Kitchen Ranges Logo
71 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Dale Copeland
Dale Copeland
Len
Level 1 Expert
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
