How to wire a LR-8824 to a couple of external lights.
I have a melted wire coming from the back plug on my headlight switch . green and white wire. i also have 3 melted wires going to my trunck lid . from my lr tail light . dont know what to do . can u help ...
The problem is a short to ground in your running lights circuit. From your description, it seems likely that the short is somewhere in the wiring to your lr tail light. You need to replace those wires all the way from the tail light to the switch, and that should solve the original problem.
Feb 18, 2011 | 1992 Volkswagen Cabriolet
Need the wiring diagram for the 2009 Toyota Corolla
standard radio--------------------
Battery LIGHT BLUE (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna TAN (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Dec 12, 2010 | Car Audio & Video
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
Color code radio wireing 2001 malibu
Battery Orange +
Accessory Yellow + Note this vehicle does not have a dedicated accessory turn on wire . use a lead from the ignition switch or fuse panel to supply accessory voltage .
Ground black -
Illumination Gray +
Dimmer Brown +
Lf Speaker Tan +
Lf Speaker - gray
Rf Speaker + Light Green
Rf Speaker - Dark Green
Lr Speaker + Brown
LR Speaker - Yellow
rr speaker + Dark Blue
rr speaker - light blue
Aug 28, 2009 | Car Audio & Video
I need a wiring diagram for my bluebird
Here you go.
Battery: blue/yellow
Accessory: gray
Ground: brown
Illumination: green
LF speaker (+): pink
LF speaker (-): violet
RF speaker (+): light green
RF speaker (-): blue
LR speaker (+): black
LR speaker (-): yellow
RR speaker (+): red
RR speaker (-): white
Jun 03, 2009 | 1990 Toyota Corolla
What wires are for what?
Battery ORANGE (+) RADIO HARNESS
Accesory YELLOW (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Power Antenna PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Apr 15, 2009 | Car Audio & Video
Radio wiring info
Battery LIGHT GREEN (+) RADIO HARNESS
Accesory BROWN (+) RADIO HARNESS
Illumination DARK GREEN/WHITE (+) RADIO HARNESS
Dimmer DARK GREEN/BLACK (+) RADIO HARNESS
LF Speaker (+) GREEN/RED
LF Speaker (-) LIGHT GREEN/WHITE
RF Speaker (+) RED/BLUE
RF Speaker (-) LIGHT GREEN/BLACK
LR Speaker (+) YELLOW/WHITE
LR Speaker (-) YELLOW/BLUE
RR Speaker (+) GREEN
RR Speaker (-) GREEN/BLUE
Radio Security YES
Sep 12, 2008 | Hyundai Motor 1996 Elantra
Wiring diagram
Jul 13, 2008 | 2006 Chevrolet Silverado 1500 2WD
42 people viewed this question
 Grubhead
Grubhead
