Question about Gateway LT2802U 10.1 WSVGA 1024X600 SLIMBODY LED Screen
Gateway lt2802u won't boot up has blue light and fan shuts down
5 Suggested Answers
xalint1
  • 150 Answers
SOURCE: Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Posted on Jul 29, 2008
  • 10406 Answers
SOURCE: My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Posted on Jul 17, 2010
  • 1288 Answers
SOURCE: blue screen shut down now black screen fan running
Assuming you have already tried the power adaptor and that is ok and the charging port is not loose, I think the problem may lie in overheating. The CPU will stand up to 90 degrees c but the graphics chip, which is cooled by the main fan as a secondary consideration will not.
You should remove the inspection hatch (I think on the gateway models there is a larger hatch under the laptop) and see if there is any build up of dust or debris around the cooling fan. heatsink and radiator / vents. If there is, remove it with a paint brush or hoover.
If this does not resolve the problem/ or the fan is clean, remove each ram module in turn and try booting.
If there is still no signal, try it on an external monitor, if you get a picture, the issue is with a failed screen / inverter or VGA cable. If you do not get an image, I'd stick with my original thoughts that the graphics chip has been damaged
Posted on Jan 18, 2011
  • 45 Answers
SOURCE: ms2285 gateway shut down on it's own now it won't restart
Bring it to the computer manufacture gateway to diagnose the problem.
Posted on Oct 21, 2012
How to enter bios on gateway LT2802u?
i can tell you what to try... its going to be the delete key, f2, f10, or f12... when the machine is first starting to turn on (boot) steadily tap one of those keys and it will get you into the bios. try del first, if that doesn't work, then try f2... go down the line, one of them should work for you.
May 08, 2014 | Gateway M305CRV Notebook
Ms2285 gateway shut down on it's own now it won't restart
Oct 21, 2012 | Gateway MS2285 15.6in Laptop X2 2GHz 4GB...
Nv79 shuts down
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 15, 2012 | Gateway Computers & Internet
Gateway NV78 laptop turned off and won't reboot.
So reformat a computer that can't access the hard drive, interesting trick. I believe the OP said the machine hangs in limbo with Power Lights on, I assumed the Lights are on, but no one is home, sort of like some of these solutions. Why am I not paid millions of dollars for being the smartest man alive?
Aug 12, 2012 | Gateway Computers & Internet
My gateway laptop automatic power off ? way
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 26, 2012 | Gateway Computers & Internet
Toshiba A135-S4527 starts to power up then shuts down.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
Gateway gt4016 desktop, s/n gcm64 110 54982 unit will not boot up, pressing power button, fans starts, yellow light comes on, then shuts down. cleared cmos, pressed power button unit will boot up but...
the cpu could be over heating make sure its secure if you like get some thermal paste from your local pc world put a little on the top of the cpu under the cpu fan and replace fan securely might work be carefull....bonnell
Sep 17, 2011 | Gateway GT4016 Desktop PC
I have had a plethora of issues with my gateway as well
Yes gateway does have a bad rep and dell is slowly heading the same way.
Aug 31, 2009 | Gateway GT5220 PC Desktop
Gateway LT2802U 10.1 WSVGA 1024X600 SLIMBODY LED Screen Logo
16 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
