Question about Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only
How can i get my intex sand pump to vacuum it loses prime when i connect it
    Top Expert:
  • Intex Master
  • 7,884 Answers
Make sure hose has water in it before you connect
Posted on Apr 27, 2016
5 Suggested Answers
  • 79 Answers
SOURCE: my intex pool pump is surging and won't stay primed???
i think its pump side first as its easier to push water through a filter rarther than trying to **** it , Also the only reason it could loose its prime is through air getting in the system.
Posted on Jun 06, 2009
SOURCE: can i hook up a intex pump to a sand filter
YES BUT PRICE OF SAND FILTER WILL PROBALLY COST MORE THAN THE POOL ITSELF
Posted on Jul 13, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: how do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
  • 8404 Answers
SOURCE: I have a 12x24 rectangular
I am not an expert on your particular Intex model ...
I believe your pressure readings are with in normal parameters. Is your water clean?
Is it balanced? Your goals should be Alkalinity of 100 (no less than 80 and no more than 120, pH should be 7.4 (but no less than 7.0 and no more than 7.8) and your chlorine should be 5 ppm. I recommend a DPD test kit Cyanuric Acid should be about 50 but no less than 40 and no more than 80. Cyanuric Acid is also called stabilizer. Its function is to protect the chlorine you are making in your cell. Refer to your owners manual for how much salt you should have in your pool. 3200 ppm salt is a window to shoot for. You can get a test kit for salt. Salt, like calcium, is persistent in the water. The only way salt and calcium get out of the pool is through back washing, splash out and what you carry off with your swimming attire. Chlorine is affected by the sun and materials introduced into the water by the swimmers as well as what jumps, falls or hops into the pool. pH is not necessarily affected by the sun but the other factors do come into play. A properly balanced pool (alkalinity-wise) will not have pH "bounce". If your pH is bouncing, that is an indicator that your alkalinity is out of whack.
If your pool is 4 feet deep, you have about 8,640. Your goal should be for a 8 hour turn over rate (your pump should be pumping no fewer than 1,120 gallons per hour). BTW, studies show that if you run your pump 24/7 with a 8 hour turn over rate, it still takes up to 5 days for every drop of water in your pool to actually pass through the sand.
You could install a flow meter in your return line. It is simple to do - drill a hole in the return line and attach the meter. Rule of thumb - a 1.5 hp motor (probably bigger than yours) will move about 50 to 70 gallons per minute through a 1/5 or 2.0 pipe. A 2 HP motor will move between 60 and 80 gallons per minute through a 2 inch pipe (and filter, of course). Get a flow meter at your full service pool supplier. It will come with full particulars.
With a clean filter (note the pressure) you should back wash when the pressure increases by about 10 PSIG (Pounts Per Square Inch on the Gage) from the pressure when clean.
I hope this information helps you ...
Thanks for your question @ FixYa.com
Posted on Aug 04, 2011
70110 sand filter. how do I connect a vacuum hose?
hook up to your skimmer over the basket to catch leaves
Jun 24, 2015 | INTEX Sand Filter Pump
Sand Filter Pump
sounds as if you either have a clogged skimmer or a colasped hose , for this type stuff to happen
i have used coils of thick copper wire (dont rust) to keep hoses from sucking closed
Jul 08, 2014 | INTEX Sand Filter Pump
Sand comes out after backwash and rince
Sand comes from where? Losing some sand is normal
Jun 07, 2014 | INTEX Sand Filter Pump
New intex above ground pool sand filter has no way to vacuum it
i do believe that intex sells a kit to vac the pool ,it includes a plastic scoop that fits in skimmer to go to bottom vac wand
me i saw a photo of kit and made one out of an old vinegar container i cut the bottom off of and a length of old hose from a wet /dry vac and i use that to run around bottom to suck up solids (gotta fill hose first before connecting it )
Jun 05, 2014 | INTEX Sand Filter Pump
How to prime a sand filter pump
use a garden hose connected to house supply to fill the housing and pump head , after that Pump should be able to take over and use water pulled from skimmer , if all your joints and seals are good , if it looses prime ,even after resting for a little while , ck all your joints and seals for leaks ,remember not all leaks ,Leak Out some leak In !!
Apr 23, 2014 | INTEX Sand Filter Pump
It depends on the pump but most pumps have a filter bowl with a screw on cover - you need to fill this with water and start the pump. if the pipework connected to the pump and the filter are empty you will usually have to repeat this process a few times, but once the pump is primed it should start up without repriming in future - Hope this helps - Nigel
My 24' above groung pool with a 1.5hp pump and sand filter ssems to be losing prime when i hook up my aqua critter. If i unhook the critter the pump re-primes. Any sugguestions as to why?
Your hose either has a hole in it, at the sections at the waters surface where it is exposed to the air? Even a "Pin" hole will create the symptom you are experiencing.
Or... there is a clog in the unit itself.
It appears that you are either sucking in air, or the water flow is being blocked. The pump should pull water no problem through a vacuum hose or a suction style pool cleaner. If the pump loses prime, then "Water" flow is being restricted either physically are mixing with air.
Aug 13, 2013 | Hayward SAND FILTER, PRO SERIES
I have no suction at the skimmer.
maybe your pump has lost it's prime? prime the pump with it OFF and use a garden hose connected to house supply , remove hose and turn pump ON you should see dishcharge shoot out some bubbles at first then they should dissapate in -60 seconds , if bubbles continue, you have a suction side leak in maybe a filter lid or hose connection this will make the filter loose its prime after every off cycle
Jun 17, 2013 | INTEX Sand Filter Pump
Sand filter losing prime
You will see NO leak if the pump is on.
But once the pump is off, then you may see a leak.
Jul 23, 2012 | Hayward Pool & Spa
Are vacuuming the pool . My sand filter does not work right it has no pressure going out to the pool. a pool store said it might be air bound .bleed the air out same thing
Do you have problems priming the system? If so you may have a suction leak in the plumbing attached to the front of the pump or a bad 0-ring seal in a valve. Symptom would be that when you set up to vac. The pump would lose prime or move very little water. Also maybe a clogged pump impeller.
May 27, 2010 | Hayward SAND FILTER, PRO SERIES
Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only Logo
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
