Question about Samsung SCX 4521F All-In-One Laser Printer
How to clean glass on photocopier? - Samsung SCX 4521F All-In-One Laser Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
Use lint free cloth .
can use any glass cleaning agent
Posted on Oct 02, 2015
Have more lines what I do
More lines when printing or photocopying?? What color lines? For lines when printing, clean charge rollers of the respective PCUs. If not, replace PCU drums. For lines that are appearing only when photocopying, check if the slit glass or flat bed glass have white out liquid correction ink markings on them. If yes, clean them. If not, clean scanner lens and mirrors of the scanner assembly.
Mar 11, 2014 | Ricoh Aficio MP1600SPF Copier
There is Dark spots on paper when a photocopy is done
Most likely there is something on the glass or something ie: dust underneath the glass that gets in the way of the scanner and the paper(dots) or on the scanner itself(streak). I have heard many times that photocopy machines in cvs/wall greens, any kind of commercial copy places and even libraries deliberately mark on the glass with permanent marker to prevent any kind of copy fraud. You can clean the glass with rubbing alcohol or goof off to remove any stubborn ink on the glass and then use some Windex or something, but if its underneath the glass or on the scanner bar you will need to take some stuff apart clean it and place it back. IF you do that make sure its SUPER clean and you dont leave any finger prints on it
Feb 04, 2014 | Sharp AR-M207 All-In-One Laser Printer
Line thru the documents when using top feeder
you didn't state model #, but raise your feeder up and look for the "skinny" piece of glass on left side of your large glass and make sure you clean it well.
hth,
razors
Nov 28, 2011 | Brother Office Equipment & Supplies
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
Printing very light.....replaced toner and drum. still can barely see the print
Are you printing from your PC or using the machine to photocopy? If you are using the photocopy function using the ADF or placing the original directly on the glass...clean these area using a damp cloth. It would be better to remove the glass and wipe clean the mirror, lamp assy, and lens.
" do this only when power code is removed from power source"
If you printing from your PC...- check the configuration of the printer setting.
Feb 22, 2011 | Sharp AL-1655CS Copier
CANON IR1022A PLATEN GLASS
Once you clean the glass, you must power down the unit completely. They error won't reset automatically.
Mar 05, 2010 | Canon Office Equipment & Supplies
Brother MFC 9880 - When I copy a document using the flatbed feature I get several black lines or strikes at the bottom of the photocopied page. If I use the automatic feeder the photocopied page is...
Your glass is dirty. The reason you don't get it from the ADF is because it uses a smaller different glass ahead of the glass that you use when you put it on the scanner. Clean the glass using a lint free cloth and some glass cleaner or, better yet, lens cleaner.
Jun 20, 2009 | Brother MFC 9880 All-In-One Laser Printer
Vertical lines slanted on photocopier
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Feb 17, 2009 | Ricoh Office Equipment & Supplies
How do I find the copy count for a Canon MF 6530?
We have a photocopy canon MF 6530 and on the screen appeared information Platen glass dirty , clean platen glass.
I have clean glass there we put paper for copy , but it seems that is not this problem, Photocopy stoped copy or print it use just paper.
Could you please let me know what do I need to clean.
Yours sincerely
Gintas Vilpisauskas
Jul 30, 2008 | Office Equipment & Supplies
MP780 photocopies made using ADF have a line which obscures content
I tried the other solutions listed her - and no luck. After cleaning the ADF rollers, like the manual suggested - no change.
I finally figured out why things that I coped with the ADF had lines/marks on them, but those placed directly on the platen (glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Nov 24, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Samsung SCX 4521F All-In-One Laser Printer Logo
32 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
