Question about Compaq Evo N610C Notebook
Cd/DVD combo not detected by windows , when i placed the CD i am not getting any lights on CD drive
    President:
  • 1,185 Answers
Your drive has died and needs replacing
If no lights come on there is no one home
Easy to change , remove the two screws with arrows against them on the bottom of your laptop.
Put a paperclip into the little hole on the front of the CD unit and press , The door will pop open and you use the door as a lever to gently rock the unit and remove it.
It is worth removing it and then putting it back again just to check for a dirty connections on the connector at the rear of the drive
Posted on Jun 22, 2009
Seems to be a problem with the hardware. plz get it check with the compaq service center.
    Sergeant:
  • 193 Answers
Sounds like the jumper setting is wrong, take it out and out it as master or if you are already using a drive as Master then change it to CS (cable select).
Computer doesnt detect drive
Not exactly The computer detects the drive but windows does not detect the driver. Uninstall the drive in the Device Manager and Restart the computer. This will reinstall the driver..
Nov 29, 2013 | Panasonic (CF-VDRRT1M) CD-RW/DVD-ROM...
I have a TDK DVD/CD burner that my computer does not recognize. When I turn it on my computer makes a sound like it knows it has been turned on but when I go to burn a music cd it says that there is no CD...
hi blgard,
please ensure u have wired up this internal combo drive properly,
- that IDE cables and power cable is connected, that the jumper setting
is properly(if using this as a single drive without any harddrive connected to the same IDE cable jumper must be set to single!)
- that in BIOS both ODE channels are activated and drive detection is set to auto
when done this properly, the drives will be listed when booting up(press pause button, right before windows is loading, to see list)
if not, use the other channel(echange IDE plugs on the mainboard), retry
and see.
when booting the green lamp of the drive should light up shortly!
then goto windows/setting/hardware, run hardware detection/device manager and wait for the new device to show up. Make sure you have the driver CD ready for windows will ask for it, (if you don't have another cd-drive ready, copy content of cd onto usb-stick/thumbdrive instead )
le win search for the drivers on the cd/usb-device,
proceed installing, finish and reboot.
if now windows can't find the drive (see win explorer)
but it is listed when booting up, get the latest drivers from the manufacturer's homepage and reinstall drivers!
I hope this works for You!
Sep 07, 2009 | TDK (ai-4800drombx-b) CD-RW/DVD-ROM...
Dvd drive not detected
Try unistalling the cd drive using your device manager. After removing it from there reboot and see if it is correctly identified and installed by Windows. If not you can manually install the driver or firmware from the drive manufacturers website. Hope this helps.
Jul 26, 2009 | IBM (33P3227) CD-RW/DVD-ROM (Combo) Burner
Acer 4520 cd/dvd driver problem
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
May 28, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Working only with CD, but can not start any DVD
open your device manager , off a right click from ,,, my computer . click properties , hardware tab , then un-install both the cd and dvd . re-start your system and let windows detect the new hardware and re-install it for you . Let me know if this works .... if not we can troubleshoot further.
good luck
May 24, 2009 | BenQ CB523C CD-RW/DVD-ROM Combo Drive
Samsung CDRW/DVD SM-352F
First i need you to make sure that both the BIOS and the WINDOWS is detecting your drive as 'combo' drive. If not, your drive is not combo, it is CD drive only.
Because both rely on the product ID that is built into the Drive.
If u are confirmed of the fact that your drive is COMBO, then the problem might be with the laser.
Combo drives use separate laser beams for DVD and CD operations, and
it's possible for one (either one) to fail while the other is still
working. But it's more common for the DVD to fail while the CD still works.
You need to contact the service center with your drive ,if that is the case.
Hope my info is useful.
Bye....
Sep 18, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
DVD not getting detected
Hi, i have LG GCC4522B CD-RW/DVD-ROM Combo Drive and my problem is that i could open & play CDs. However when i insert DVD the drive doesn't detect the DVD and it shows no DVD in drive or blank. I checked the region setting which is 1. Is it the problem of region setting if so is there any solution for this. Expecting your valuable solution in this regard.
Thanks
Moses
Aug 30, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Cant instal as have no installaltion cd
for all i know cd/dvd rom are automatically detected by windows, so there's no way it wont be recognize by the windows unless you are using win95.
May 15, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Not detecting
Dear dhavu,
me too have the same problem with samsung dvd combo drive.. no medicine fo it....
Jan 21, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Cdrom not detecting
attach another drive to your system boot your system with bootable windows cd and make your system drive c
install windows in c drive
this problem is incounter
when u install the window in other drive than c
Dec 22, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Compaq Evo N610C Notebook Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
