Question about Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8n won't crank
Ford 8n was running great but suddenly won't crank. Battery is okay, so how should I isolate the problem? And what is the most likely cause?
  • 218 Answers
Hi..my name is Keith..and the 1st things that i would check is to make sure the battery terminals and cables ends are clean..if they are..i would check to make sure the ground wire and where it connects to the frame is clean and rust free..and if they are in great condition....i would suspect the starter solenoid..i'd make sure all the connections are clean on it..and if it still dont work after you cleaned it...i would replace the solenoid..i hope this helps..and there could be other things..so if it dont solve your problem..write me back
Posted on Jun 30, 2009
Won't start !! converted to 12v ,new starter and solenoid installed along with new coil,points,roto cap now no spark to plugs
Cranks? Check voltage to + side of coil,first. 10 V. OK.
Be sure that points open and close.SEE it as it cranks.
Points gap should be around .016 "
If you open and close the points,key on,engine off,the coil should SPARK!
Use a screwdriver to get a shock. Fun.
Sorry.
The coil will spark when you short the points,when they are open.
Mar 17, 2013 | Ford 8N Tractor
I have a 1948 8n. It starts and runs great when the weather is warm, but this year it won't start in the cold. However, if I let it sit in the sun for about an hour, it starts okay. I use it just...
The problem is the carburetor is not being choked. This tractor most likely has a manual choke. Do you see a knob which you would pull to choke the carburetor ?
Are you pulling the knob when you crank the engine ? If you are pulling knob and the engine doesn't start, the choke most likley has a broken or disconnected cable.
Charlie
Jan 07, 2011 | Ford 8N Tractor
8N rpms keep falling
I run one number hotter plugs in my N tractors as they tend to foul plugs.
Glad it was a simple fix.
Apr 28, 2010 | Ford 8N Tractor
8n ford wont start when hot,plugs are dry,ethar
can u send the license key for 355664007645462 this will be help from u
Dec 11, 2009 | Ford 8N Tractor
My 8n (6 volt) will not start. Great spark getting
Spark to plugs is great?.....but if they are black (carbon coated) it may not start.
Crank her over and use that choke for 30 seconds.
Pull the plugs ...are they wet with gas?Smell it....is it water or gas.
They should be wet with something.
Are they dry.........No fuel.
If they are wet with gas and NOT black carbon coated and you are SURE you have spark..........time to tow it to start.
You want to turn the engine fast enough to have the crank throw oil onto the cyl walls. Engines need a oil coated cyl wall to run....to seal the rings.The gas from flooding the engine washes the oil away.Put it back and it should fire up.After the first start...it should be OK.
I've started many a engine that others could not start (flooded or sitting for years) with a little oil in each cyl to seal it.....but towing is the better choice if possible.
Jul 08, 2009 | Ford 8N Tractor
Ford 8N will not start when hot
This sounds like a bad fuel pump to me. The only way to be sure is to check the fuel pressure when cold, probably around 45 PSI. Then when it get hot it will drop way down to 10 or 15 PSI. Check the pressure if you can, or change the fuel pump.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 12, 2009 | Ford 8N Tractor
1950 8N FORD TRACTOR WON"T START.
Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
Apr 13, 2009 | Ford Tractor 8n Front Emblem
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
1,148 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
