Question about Panasonic Lumix DMC-TZ3 Digital Camera
How do you unlock the memory card on the Panasonic Lumix DMC-TZ3
  • Anonymous Mar 22, 2014
    what size does it take
  • Panasonic Master
  • 4,806 Answers
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this How do you unlock the memory card on the Panasonic - 59a6de4.jpg .
Hope this helps.
Good luck
Posted on Jun 22, 2009
5 Suggested Answers
  • 172 Answers
SOURCE: Lumix DMC-TZ3
Memory card likely has temporary(needs formatting) or permanent problems(needs replacing, common for off branded china junk).
First format the mem card on your camera by pressing center Menu button then scrolling down to the end of the menu to Format. If this does not work, and you have bought a Name Brand SD card; Sandisk/Kingston/Patriot etc, return it to place of purchase with receipt, or creditcard use to purchase it, and they will replace it.
Posted on Feb 27, 2009
alfa104
  • 78 Answers
SOURCE: memory card locked panasonic lumix dmx tz3
Format the sd card and try again.
Posted on Jun 13, 2009
  • 11967 Answers
SOURCE: My Panasonic Lumix DMC-TZ3 gives me a message that
Try formatting the card in the camera.
Posted on Jan 04, 2010
lock123
  • 6831 Answers
SOURCE: My memory card is locked. How do I unlock it?
What exactly is you problem with your camera?
Regards
Andrea
Posted on Sep 27, 2010
How do i unlock the memory card on a DMC-TZ7
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 11, 2014 | Panasonic Lumix DMC-TZ3 Digital Camera
How do I unlock the memory card for Panasonic DMC-TZ3. Suddenly locked - has always worked fine until today!
take the sd card out , there should be a loch on the left side when facing the card with the label up, slide the lock down and try agian or try a different card or else remove all power , wait 30 min , insert battery and try to see if the camera goes on (most pansonics have built in memory , so check if you can record a picture if yes then try the card agian )
Apr 30, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Can the Panasonic Lumix DMC-TZ3 camera be used as a webcam for Skype?
Well-not easily. It will not work through USB. An out-of-the-box camera only lets you access camera memory card/onboard memory. However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
At the moment this seems to be the only easy way to use TZ3 as webcam.
Good luck,
Raf
Mar 24, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC-TZ3 2GB Memory card says full with very few pics.
I think u have to format your memory card through ur camera setting option..
Dec 17, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic lumix tz3
There is a small switch on the memory card side, that set on and off the lock mode, if that does not fix the problem, it means that the card is defective. In that case, replace the card.
Dec 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Regards
Andrea
Nov 02, 2008 | Panasonic Lumix DMC-LS70 Digital Camera
Lumix DMC_TZ15
You try to format ur memory card....
Dec 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix TZ3
Try FORMATing the card in the camera.
Jan 08, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
1,297 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
