Question about Sta Rite Sr200lp Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 200,000 Btu Propane Gas
Sta-rite heater error code 126
All of a sudden my pool heater is not working. When I opened the pool about a month ago it was fine. Now I get a display code of 126 and it won't turn on. I've seen this commonly reported. What does it mean?
  • 83 Answers
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
Posted on Jul 10, 2009
  • jimtee58 Sep 20, 2011
    I had the exact same problem listed here (having a 126 on the control board for the Sta-rite heater). After reading this update, I decided to order the part and I installed it this afternoon. It was the right answer for my problem.
  • SamG Jun 17, 2013
    I have the same issue and replaced the Thermister but this didn't fix the problem. I am still getting the same error which is 126 e13.
Sta rite pool heater
Good SHOT! That's likely to be the problem - that or a poor connection.
Aug 03, 2014 | Sta Rite 200 Btu Propane Gas Heater...
Sta-rite pool heater won't fire...
www.cheappoolproducts.com/.../Max-E-Therm-manual.pdf - United States
https://www.gpspool.com/.../Sta-Rite/Tech%20-STA-%20Servicing%20the%20Heater%20Control%20Board%20%u2013...
Those manual should sort you out.
May 29, 2010 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
It reads 126
That is not a code. Look under the cover on the circuit board for red light.
Jul 19, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite Sr200lp Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 200,000 Btu Propane Gas Logo
3,686 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
