Question about Westland Xpress Alumaweld Boat Cover - 1650 VJF WITH Seats Down O/B Hood Not Incl. 05 - 05 Sharkskin Plus
Boots on toggle switches - Westland Xpress Alumaweld Boat Cover - 1650 VJF WITH Seats Down O/B Hood Not Incl. 05 - 05 Sharkskin Plus
Speedometer quit working,possible causes?
Many possible causes
THEORY OF OPERATION
The 2001 electronic speedometer consists of a speed sensor, an odometer reset switch and the speedometer itself. The speed sensor is located on the right side of transmission case below the starter. It is a Hall Effect sensor that is triggered by the gear teeth of 4th gear on the transmission mainshaft. The output from the sensor is a series of pulses that are interpreted by speedometer circuitry to control the position of the speedometer needle and the liquid crystal (LCD) odometer display. The odometer mileage is permanently stored and will not be lost when electrical power is turned off or disconnected. The odometer reset switch allows switching between the odometer and the trip odometer displays. To zero the trip odometer, while having the odometer display visible, press and keep the function switch depressed. The trip odometer mileage will be displayed for 2-3 seconds and then the trip mileage will return to zero miles. The odometer can display six numbers to indicate a maximum of 999999 miles. The trip odometer can display six numbers with a tenth of a mile accuracy for a maximum of 99999.9 miles. Circuitry in the speedometer also uses the sensor input to provide an input to the turn signal canceller. This turn signal canceller input was previously supplied by the reed switch in mechanical speedometers.
DIAGNOSTICS
To enable diagnostic mode depress the odometer reset switch and turn ignition/key switch to ON, to clear codes turn the ignition switch from OFF to ON while holding the reset switch in. Press and release the reset switch to cycle through the codes. Set codes will display as Code d0xSet. Holding the reset switch in will result in Code d0xClr being displayed indicating that the code has been cleared. To return the speedometer to the normal operating state cycle the ignition/key switch.
Remove the seat for testing. Remove the speed sensor and check for accumulation of debris on it and if there is any debris present, clean it away and if there is not debris replace the sensor.
Disconnecting the speed sensor will cause code d02 to set.
ODOMETER, TRIP ODOMETER AND RESET SWITCH TESTING
Turn the ignition ON. Does odometer display consist of the correct numbers?
If YES Press trip reset switch. Does the LCD display toggle between trip and odometer modes? BUT if the odometer display does not consist of the correct numbers replace the speedometer.
If the speedometer does display the correct numbers press the trip reset switch. Does the LCD display toggle between the trip and odometer modes? If No Loosen the trip reset switch boot and then tighten it again until it is snug and toggle the switch again and verify if it toggles between trip and odometer modes? If YES does the trip display consist of correct numbers? If it does STOP here and go to test 2A If No replace the speedometer.
If loosening and retightening the reset switch boot results in okay toggling between the trip and odometer modes the Speedometer is OKAY. If it does not, then remove the rubber boot from the reset switch and toggle it without the rubber cover and if it now toggles between the trip and the odometer modes replace the reset switch boot/cover. If it does not now toggle between the trip and odometer modes place a jumper wire across the leads to the reset switch on speedometer connector. Does the LCD display now toggle between the trip and the odometer modes? If yes replace the reset switch and if No replace the speedometer.
Speedometer Test 2A
SPEEDOMETER INOPERATIVE, READS HIGH/LOW, NEEDLE STICKS, INTERMITTENT/ERRATIC, OUTPUT SPEED SIGNAL INOPERATIVE
Turn ignition ON. Is speedometer backlighting on? If NO then If speedometer backlighting is not on, check for 9-12 VDC on the O/W wire at connector
[39B]. If the proper voltage is present check for continuity to ground on the BK wire at connector [39B]. If there was not appropriate voltage on the )/W wire at connector [39B] locate and repair an open in the O/W wire.
If there is continuity at the BK wire at connector [39B] replace the speedometer. If there is not locate and repair an open in the BK wire.
If there is backlighting enable diagnostic mode and clear codes. Then recheck for codes. If there are any codes present go to the applicable
code in Speedometer Test 2B (d0x).
If there are no codes set return the speedometer to its normal state, raise the rear wheel from the ground, put the transmission in 5th gear, turn the ignition ON, spin the back tire, enable diagnostic mode and check for codes and if there are any codes set now make repairs to the harness/connections.
May 01, 2014 | 2000 Harley Davidson FLHR-FLHRI Road king
Speedometer not working 2000 harley davison and engine light is on
Here is some 2001 information that may be helpful
The 2001 DYNA electronic speedometer consists of a speed sensor, an odometer reset switch and the speedometer itself. The speed sensor is located on the right side of transmission case below the starter. It is a Hall Effect sensor that is triggered by the gear teeth of 4th gear on the transmission mainshaft. The output from the sensor is a series of pulses that are interpreted by speedometer circuitry to control the position of the speedometer needle and the liquid crystal (LCD) odometer display. The odometer mileage is permanently stored and will not be lost when electrical power is turned off or disconnected. The odometer reset switch allows switching between the odometer and the trip odometer displays. To zero the trip odometer, while having the odometer display visible, press and keep the function switch depressed. The trip odometer mileage will be displayed for 2-3 seconds and then the trip mileage will return to zero miles. The odometer can display six numbers to indicate a maximum of 999999 miles. The trip odometer can display six numbers with a tenth of a mile accuracy for a maximum of 99999.9 miles. Circuitry in the speedometer also uses the sensor input to provide an input to the turn signal canceller. This turn signal canceller input was previously supplied by the reed switch in mechanical speedometers.
DIAGNOSTICS
Speedometer Test 2A
Jun 26, 2011 | 2000 Harley Davidson FXD Dyna Super Glide
The screen on my packard bell L110 notebook seems to have frozen - it's just dark as if it's not switched on - have i somehow locked the screen?
Your screen my have toggled off.Try pressing Fn+F5 while the system is truned on to see if you can toggle it back on. You may have to press the key combination several times to get it to work.
Mar 03, 2011 | HP Computers & Internet
Where is the red switch that is turned off when servicing Audiovox pretige remote car starters?
there is usually a red toggle switch down in the kick panel or on the knee bolster. It is silver and has a red rubber boot on the toggle switch. This may not be there if the tech did not install it.
Dec 06, 2010 | Car APS921 Remote Starter - Keyless Entry
My computers seem to have become somehow linked by the KVM switch
The GCS632U is just one KVM switch. But if you're going to check it out, it has actually two separate connections.
It will just switch once you toggle from one computer to another.
Try to power cycle the KVM switch.
1. Shut off both computers.
2. Disconnect the KVM switch from the computers. (make sure that not even a single cable is connected to the computer, even the audio).
3. Leave it disconnected for 10 minutes.
4. Reconnect the KVM and boot up the XP first.
5. Boot up the Vista, try to toggle from one computer to another.
6. LASTLY, shut off the Vista and see if same problem will occur.
If you get the same problem, then you need to contact IOGEAR and have them RMA the device. Because this is the first time that I heard of this problem.
Thank you and good luck!
Jan 25, 2010 | IOGear GCS632U 2-port KVM Switch
Bought a replacement driver side mirror, cant find where to unplug the old one.
Is there a mirror control toggle on the inside of the automobile?
If there is, and it has a rubber boot, you should be able to remove the rubber boot and find screws to release the mirror.
If there is no toggle switch, perhaps the mirror assembly snaps off. Yo might ask the dealer as well.
Oct 07, 2009 | Dodge Caravan Cars & Trucks
Boot will not close, warning lamp says :"boot open" and the lights in the car will not turn off, even if it in fact is closed......
It seems that you have a faulty switch. I can't be sure where it is on your car, but I believe that it is tied into the latch mechanism of the boot. It could also be located somewhere along the boot lid or the body where the boot and the body meet up. It will be a toggle switch about the size of a nail that you can press in and out
Aug 07, 2009 | BMW 525 Cars & Trucks
Computer won't boot , constant PWR problem (
i am also using same motherboard dg31pr intel but it does not reboot .......
because this is the problem with you monitor , just you change the monitor and try again .
this is only the solution to solve this as the tecnition said me.
Mar 20, 2009 | ASUS A7V400-MX Motherboard
I need to know how to wire my deck.
buy a toggle switch
run a wire from the red wire located at the back of deck
to the deck and toggle switch (power to power on toggle switch)
do the same with the ground wire (black) (ground to ground on toggle switch) (make sure to follow logos on toggle switch)
finally install e brake wire to center pin on toggle switch
now you can watch make sure toggle switch is on
if this didn't work switch the e brake wire and black wire on toggle switch
good luck hope i helped
Dec 08, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Westland Xpress Alumaweld Boat Cover - 1650 VJF WITH Seats Down O/B Hood Not Incl. 05 - 05 Sharkskin Plus Logo
46 people viewed this question
Top Westland Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Westland Boating Expert? Answer questions, earn points and help others
