Question about Nordic Track Incline Trainer X9i Interactive
Why won't my new motor start?
I've installed a new motor, resistor, and controller. The console shows movement around the track, but the motor is not turning. What am I missing? Red light on controller is flashing rapidly.
5 Suggested Answers
  • 40 Answers
SOURCE: I have a Nordic track summit 5500 and the front
sounds like a bad console. Look for a used one on ebay, but don't buy a new console, you're so much better off buying a new treadmill
Posted on Oct 25, 2009
  • 18 Answers
SOURCE: Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Posted on Mar 10, 2010
  • 218 Answers
SOURCE: the red wire to the console shows 0 dcv its
yes
Posted on Aug 11, 2010
ercupa190
  • 12223 Answers
SOURCE: my nordic track a2050 turns on but when we try and press one of the speed buttons (1-10) the r17 resistor on the controller (circuit board) starts to spark. can i change the resistor? what resistanc
Dear Sir:
If you can the change the resistor is o.k ,depending about your skill in electricity or electronic.Remember when you change, but the exactly as indicated in the board. For example the resistor has color code, I can recomend you can buy some chart from Radio Shack, for you will see the exactly value+tolerance)Very Important+Power of resistor.
Meanwhile, if the resistor is Sparking, is indicating there are some short-circuit in the board. By that reason when you change the resistor if the trouble persist, you must send the board or call some service tech from some company for assist you in this problem
Other alternative that you have is RUN THE calibration SOFTWARE,that is coming with your equipment, the instruction most of them coming from the Hood of the motor, other your must use your Instruction Manual.This is important for easy Diagnose and Troubleshooting from your treadmill. Remember this very Complex equipment electronic.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Feb 16, 2012
Testimonial: "thank you so much ernesto. you have been more than helpful. bob pollock coram, ny"
I have a Nordic track EXP 1000 the only keys that work are the start button and 1 mph. Other than that nothing else works. Not sure if it is the controller or the council. Any suggestions?
I had the problem years ago and I contacted NorcTrack and their solution was to replace the entire console for about $400. They wouldn't replace the pads or anything else, all they would do is sell me the new console. That was not going to happen since I had only had the thing for about 5 years at the time. I wasn't going to be putting that kind of money into that treadmill every 5 years or so.
I tried many things and I finally decided to buy a new console pad from the Treadmill Doctor. I think it was around $100. It was easy to replace. I just removed the screws holding the console cover in place, unplugged the wires leading to the lower console pad and pulled it off. The new pad fit exactly into the space the old pad occupied, I plugged it in and it worked. It's still working about 6 years later. I use this treadmill daily without any problems. It's not anywhere near as nice as the new units I see out there today, but it does what it's supposed to do and that's all I need.
The Treadmill Doctor has all the parts you need for this machine at a reasonable price. Much cheaper than Nordic Track.
Mar 15, 2014 | Nordic Track Nordictrack Exp 1000...
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
Installed new blower motor. bearing shelled in old one. new motor won't blow. tested . it's good don't have power to moter. fuses good relay good. isthere a circuit breaker in wiring for b
I don't have a diagram for a 2008. On 2005 models the blower motor relay gets power from a 30amp fuse.
When the blower switch is in the high position the resistor is bypassed and power flows directly to the motor. The motor is grounded to the car.
The fan relay also gets power from a 7.5amp fuse and is controlled by the HVAC control on the dash.
Do you have power into and out of the relay?
Feb 25, 2013 | 2008 Mitsubishi Lancer
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
POWER SEATS WONT WORK
We had this problem numerous time (luckily while under an extended warranty) our local dealer tried fixing it many times, they even put a heavier motor under the seat. After one repair the seat motor stopped working within 2 miles. My husband turned around stayed out in the shop and helped the mechanic discover that when the seat went back at a certain point, the wire under the drivers seat was routed so that it traveled into the seat track and back out, when it went into the track it got pinched and shorted out. (you CAN NOT tell if this has happened by looking under the seat, the wire will NOT still be trapped in the seat track or severed, at a certain point the wires traveled into and then back out of the track causing a main wire to short out (wires are harnessed under the drivers seat which control movement in both seats). The solution - a new wire harness was installed and the wires had to be routed differently to prevent this from happening. The repair only took a few minutes the wire harness had to move over about three inches and the wires got ties to hold them out of the way. That was three years ago and so far this has not been a problem again. Hope this helps, or gives you some place to start looking.
Aug 30, 2010 | 2005 Chrysler Pacifica
Volvo air conditioning doesnt work s60
you need a blower motor resistor
Oct 30, 2009 | 2001 Volvo S60
Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Oct 29, 2009 | Nordic Track NordicTrack Treadmill, A2550
Heating
"Blend door stuck and clicks on your 2003 Ford Explorer?\" FIRST BUY OEM BLEND DOOR MOTOR $57.00 + UP TOOLS NEEDED : PANEL TOOL OR FLAT BLADE SCREWDRIVER ,1/4 SOCETS 7 & 8MM ....1/4 HANDLE...1/4 SMALL EXTENTION...1/4 RATCHET NO NEED TO REMOVE WHOLE DASHBOARD!!! REMOVE TWO7MM SCREWS FROM THE BOTTOM OF STEERING PANEL & PRY AND REMOVE PANEL. NEXT REMOVE TWO 7MM SCREWS ON BLACK PLASTIC STRIP THAT YOU SEE AFTER REMOVING STEERING PANEL....PRY THIS STRIP OF PLASTIC OUT JUST A LITTLE AND CUT IN THE MIDDLE . NEXT REMOVE TWO 7MM SCREWS FROM AROUND TOP OF INSTRUMENT PANEL (BY GAUGES ) PRY PANEL STARTING FROM AROUND VENT ON LEFT BY DRIVERS DOOR ""THIS PANEL WILL STAY IN PLACE LOOSE... NO NEED TO REMOVE!"" NEXT YOU WILL SEE 0NE 7MM SCREW BY GEAR SELECTOR AREA.. BEHIND THE LOOSE PANEL REMOVE THIS SCREW.. ALSO IN SAME AREA BUT LOWER THERE IS ONE 7MM SCREW THAT NEEDS TO BE REMOVED THAT HOLDS LOWER DASH PAD ITS FOUND BEHIND LOWER CORNER OF DASH PAD.( LOWER DASH PAD GAS PEDAL AREA ) "DON'T"!!! REMOVE THE FOUR 10MM BOLTS!!!! IN SAME AREA NEXT REMOVE RADIO /AC CONTROL TRIM WITH THIN SCREW DRIVER OR PANEL TOOL IT HELD IN BY SIX CLIPS...NO NEED TO DISCONNET ANYTHING IT WILL STAY THERE HANGING!! NEXT REMOVE TWO CENTER CONSOLE LOWER LARGE PLASTIC CLIPS BY FLOOR MATS. NEXT UNDER SQUARE BLACK RUBBER AT CENTER CONSOLE REMOVE ONE SILVER SCREW. MOVE SEATS FOWARD AND REMOVE TWO 8MM SCREWS FROM SIDES OF CENTER CONSOLE FROM BACK SEAT. PRY CUP PANEL SECTION THAT WAS HELD DOWN BY SILVER SCREW ...PRY UP TOP HALF OF CONSOLE STARTING FROM SECTION WHERE ARMREST DOOR IS.. DISCONNECT LIGHTER PLUG AND REMOVE PANEL . NOW YOU WILL SEE SIX SCREWS STARTING FROM BELOW RADIO TRIM WORKING BACK TO ARMREST DOOR .REMOVE ALL SIX..THESE HOLD THE BOTTOM PORTION OF THE CONSOLE ALSO DISCONNET ONE BLACK PLUG AND PULL ALL THE WIRES CLIPPED DOWN...PULL BOTTOM PORTION OF CONSOLE TO BACK SEAT. PULL LOWER DASH PAD GIVE A NICE TUG.. IT SHOULD MOVE OUT A LITTLE ..DID YOU REMEMBER ONE SCREW BEHIND CORNER DASH..!.STARTING FROM AREA BY GAS PEDAL LOOK UP IN THIS AREA YOU WILL HAVE ENOUGH ROOM TO GET A LONG EXTENTION WITH AN 8MM SOCKET TO REMOVE 3 SCREWS HOLDING MOTOR TO BLACK PLASTIC SECTION.. REMOVE SCREWS DISCONNECT SMALL BLACK PLUG AND PULL MOTOR FROM SOCKET GOING TOWARD DRIVERS DOOR DIRECTION. ALIGN NEW MOTOR SHAFT WITH SOCKET TIP.......IF NEED BE..... YOU COULD PLUG MOTOR HARNESS INTO NEW MOTOR THEN TURN IGNITION ON AND MOVE HEATER/AC CONTROLS TO GET THE SHAFT LINED UP..DONT MOVE ANY OTHER WAY!!!!!! NOW PUT SHAFT INTO SOCKET MAKE SURE YOU CONNECTED THE PLUG IF YOU HAVEN'T ALREADY!! INSTALL 8MM SCREWS AND TRY IT OUT YOU SHOULD HAVE HEAT NOW NOW INSTALL EVERTHING BACK IN REVERSE ORDER
Sep 29, 2008 | 2003 Ford Explorer
Nordic Track Incline Trainer X9i Interactive Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
