Question about LG DLG5932W Gas Dryer
Dlg gas dryer solenoid ignition problem - LG DLG5932W Gas Dryer
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Replace solenoid
Posted on Jun 29, 2014
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Posted on Dec 28, 2008
muntejaya
  • 10421 Answers
SOURCE: LG DLG 5988 B (LP), Dryer runs but no heat. Gas
You have heater problem and need to fix .
Posted on Dec 17, 2010
heatman101
  • 43501 Answers
SOURCE: LG DLG 2526W dryer running but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Maytag atlantis gas dyer not heating
Can you look inside the door for your model number. I believe the problem is either a defective igniter or defective solenoid coils that open the gas valves=> 279834 Gas Valve Solenoid Set
4391996 Dryer-Igniter
Here is a Manual=> Atlantis_Neptune_Electric_and_Gas_Dryer_Service_Manual
I will be here if you have questions, Thanks Sea Breeze
Feb 28, 2013 | Dryers
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
LG DLG8388WM won't heat ...
It could be a clog in the supply pipes inside the dryer itself or a faulty regulator your best bet it to find a local repair shop as dealing with any gas appliance without proper knowledge can destroy your appliance or worse you PS: do you smell gas when it runs if so then it could be the igniter is faulty!
Nov 13, 2009 | LG DLG8388 Dryer
What do I do if the gas coils are bad on my HE3 Kenmore gas dryer 92132100? The igniter glows.
There are two gas control solenoids on the dryer. If the igniter is glowing that does not mean that it is not bad. One solenoid opens when the igniter is fully heated and the other opens when the door is closed and dryer is running. The igniter may not be reaching the full temp to open th solenoid or the other solenoid may not be working. First you should make sure the gas on the dryer is on and not restricted. Make sure the gas connector is not kinked and the line/regulator screen or free from debris. Give the appliance regulator at tap with a wrench(may be sticking). When the gas solenoids are getting power they will be magnetic at the top. When you touch a piece of metal to the top of them they should be magnetized. You could also tap the solenoids lightly(they could be sticking). The hot surface igniter can be tested with a ohm meter or you can take it to an appliance parts store and sometimes they will test them for free. Sounds like it could be a bad gas solenoid valve.
Sep 08, 2009 | Kenmore 94072 Gas Dryer
Dryer worked well until recently. Igniter glows
I would take a look at the gas coil solenoids. The gas coils are right above the gas valves. They are black electrical coils. When energized, the coils open the gas valves. If one or more of the coils is defective (bad solenoids), then the gas valves won't open and the gas cannot ignite. Because it's difficult to test the coils, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
Jul 28, 2009 | Dryers
Dlg 5932 dryer
Your igniter should have no resistance, meaning the igniter test should be the same as touching the 2 probes together on multi-meter or the reading should be infinite. They are very easy to break so when replacing use care.
Your part number for a new igniter is 37001308
Visit my website and put part number or dryer model number into the search feature.
http://servicepartstec.blogspot.com/
If you need help I will be here, Thanks, Sea Breeze
Mar 23, 2009 | LG DLG5932W Gas Dryer
Dec 28, 2008 | LG DLG5932W Gas Dryer
Maytag gas dryer -
still may be solenoids belive it or not the coils could become weak and fail to pull open valve recommend changing both at same time
Apr 26, 2008 | Hotpoint NLL113EYWO Electric Dryer
LG DLG5932W Gas Dryer Logo
67 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
