The honeywell thermostat is blinking cooling on but not working properly
2 Suggested Answers
  • 6 Answers
SOURCE: Honeywell thermostat won't regulate temp properly
Is there a setting on your thermostat that makes the unit stay on for 10, 15, 20, 25 minutes after you reach set temp. You can change this setting by looking at your manual for the thermostat. Not sure if there is one for this thermostat but mine has one. Mine was running 15 min after set temp and making it cool down 2 degrees lower than set temp. Hope this helps.
Posted on Jun 25, 2009
The upstairs ac display is blinking cool on, but not cooling the house. The outside fan is running. please help. The downstairs display and unit working properly
Normally Honeywell will "blink" COOL ON when its in a timed delay, usually 3-5 mins. And then COOL ON will stay on without blinking. If you turn tstat off then wait about 5 mins, then turn to cool, watch for the blinking, then wait 5 more. If it doesn't turn on, check/change the batteries if it has them. Try turning the AUTO/ON to the on position to bring on the fan only. It won't cool doing this but it helps in homeowner troubleshooting.
Aug 05, 2015 | Honeywell Heating & Cooling
Honeywell thermostat "In Recovery" Message?
In recovery only shows on programmable stats. It refers to the adaptive recovery when using the programming. Over time the stat will learn how long it takes to cool or heat to the programmed set point. For example, if during the day the programming is set to 80?, and at 4:30 the programming drops to 76?, if it takes 2 hours for the temperature to reach 76?, it will learn that it takes 2 hours and eventually it will start turning on at 2:30 so that at 4:30 the temperature is satisfied instead of at 6:30, at which point it is no longer in recovery
Aug 05, 2014 | Honeywell Heating & Cooling
My Johnson Control Thermostat is just blinking AC not the snowflake or cooling. I can't see the temperature or anything like that? It' just flashing AC.
I recommend you go to Honeywell site and type in your thermostat model etc. It will give you step by step procedures and may provide the answers you are seeking.
Aug 03, 2011 | Honeywell Electronic Programmable...
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
I have a blinking snowflake icon on my air conditioner, my air will not work. My heater will work fine but the air will not come on
When the snowflake is blinking the thermostat in in a delay mode designed to protect your compressor. If it does not stop blinking in 15min the stat is bad otherwise something is wrong with the AC
Sep 26, 2009 | Honeywell Electronic Programmable...
On my honeywell rth230b thermostat, sometimes when i try to turn on the a/c, the snowflake will just blink and the a/c will not kick on. why does it do that?
They do that sometimes as a timing feature when going from heat setting the to cool setting or vise/versa. It should not do that when the thermostat is off and then you switch it to cool. Make sure the batteries in the thermostat are fresh. And make sure the thermostat is fully seated on the housing. Also check the wires are fully inserted into the connections on the thermostat housing and the wiring is correct.
Sep 14, 2009 | Honeywell Electronic Programmable...
"Cool On" indicator on for the first time- system not cooling
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH5110D1006
Click on the Link Above. At the bottom of the page is the Downloadable "Instruction Manual" for your Thermostat.
Hope i Helped
Please Rate Me
George
Apr 30, 2009 | Heating & Cooling
We have a Honeywell A/C (we believe it's a focus pro 6000) that is not working properly. The A/C unit itself is running but the vents inside the house are not cooling. We think it's a problem with the...
the honeywell is just a thermostat.my guess is the capacitor went out in the condenser when you lost power.turn the temp down on the thermostat and hit the hold button.....if it does not cool,call a service tech.good luck!
Sep 24, 2008 | Honeywell Heating & Cooling
I'm trying to turn on the central air conditioning in my new apt, and it's not working. I'm flipping the switch on the bottom right to Cool. It's blinking "Cool On" but also says...
Remove the front cover off the thermostat and jumper the power wire= r- to g==fan & r-to y==cool if it works, then its the thermostat!
Sep 01, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
