Question about Uniden BC248CLT Base Scanner
How do i stop costant satic
I have a bc 248clt 10 band 50 channel scanner and all I get constant static
    New Friend:
  • 36 Answers
Question first.... are you using an external antenna ie outside or set top inside?..............are you using an external power supply ie power box or battery?.............has yor receiver got a signal meter in it, if so whats the static signal strenth?
jon d
Posted on Jul 19, 2014
BillB-SA
  • 2761 Answers
SOURCE: need a starter frequency guide
The best frequency database is at
www.radioreference.com
Posted on Aug 16, 2009
Testimonial: "thanks that worked!"
BillB-SA
  • 2761 Answers
SOURCE: manual for Bearcat Scanner BC 140 10 channel
I couldn't locate a manual for your oldie, but it's fairly simple to operate.
  1. Turn the scanner ON.
  2. Press "Manual" to stop scanning. Use the keyboard to choose the channel you want to enter your first frequency into. If you want channel 2, press the number 2 on the keyboard and then "Manual" again. If you want channel 12, press the 1 and then the 2 and then "Manual" again.
  3. Enter the desired frequency, including the decimal point. For instance, if the frequency is 555.789, enter 5, 5, 5 and then the dot button, then 7, 8 and 9. Then press "Enter" to complete the setup.
  4. Use the "Manual" button to move to the next channel to enter the next frequency. Continue this process until you have all frequencies entered.
  5. Complete your entries and then press "Scan." Set the squelch by turning the "Squelch" knob all the way up and backing off until you hear no static.
  6. Lock out a channel that is annoying you by pressing the "Lockout" button. If you want to listen to the channel again, simply select "Manual," find the channel by entering it on the keypad and then hit "Lockout" again
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Posted on Dec 12, 2009
BillB-SA
  • 2761 Answers
SOURCE: I know how to get the basic channels in my
Bands are nothing more than frequency ranges. For example, 108 to 137 MHZ is commonly referred to as the "Aircraft Band," and you just program individual frequencies into the scanner. Some scanners have a band monitor capability, where you push a single button to search the air band, police band, etc. This is normally done by powering the scanner ON, and pressing the desired band key (on some you may need to press MANUAL or MAN before the band key).
You didn't specify the model of your scanner, and I can't give you any more detail without it (You listed your question under the BC60XLT which is a a 10-channel scanner). If this info helps, great. If not, please get back to me with the model number and I'll go into more detail for you.
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Posted on Jun 14, 2010
  • 3 Answers
SOURCE: My Mom has a Uniden BC 248CLT 10 Band, 50 Channel
hi john. im frank. most scanners that are antlong now want work in most places. but yes she may have to by a digital one. i have scanner pro 84 that has wired on the screen that cant get off.Any solutions.
Posted on Aug 06, 2013
Squelch not working
If it is a new scanner and I were having that problem I would use the warrenty and send it back to them to repair . Now if you did anything to it they will still repair it but you will be charged.
Jul 21, 2016 | Uniden BC-248CLT 50-Channel 10-Band...
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
My Mom has a Uniden BC 248CLT 10 Band, 50 Channel Scanner. She hasn't been able to get any reception lately, so I brought it home to try to fix the problem. I am finding out that the fire & emergency...
Hello hicks,
Welcome to FixYa.
My name is John, and I will be assisting you with you issue today.
You can get updated frequency's here www.RadioReference.com .
You can also download a user manual for free here www.uniden.com/pdf/BC248CLTom.pdf/index/manuals .
Hope this was helpful. Your Comments and Testimony's are always welcomed.
Thanks for choosing FixYa today and in the future.
John
Feb 26, 2011 | Uniden BC248CLT Base Scanner
Why can't i listen to aircraft pilots & tower on my Uniden bearcat BC60XLT-1? Our airband frequency here is 108-137 mhz.
Your scanner does not receive frequencies between 54 and 137 MHz, and there's nothing you can do to enable reception in that block. Your only option is to purchase a scanner with air band coverage. Here are the reception ranges of the BC-60XLT-1:
29.0-29.7 MHz 10 Meter Amateur Band
29.7-50 MHz VHF Low Band
50-54 MHz 6 Meter Amateur Band
137-144 MHz Military Land Mobile
144-148 MHz 2 Meter Amateur Band
148-174 MHz VHF High Band
Above bands in 5 kHz steps
406-420 MHz Federal Government
420-450 MHz 70 cm Amateur Band
450-470 MHz UHF Standard Band
470-512 MHz UHF "T" Band
Above bands in 12.5 kHz steps
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Bill B.
Listening in since the 60's
Feb 26, 2011 | Uniden Radio Communications
I know how to get the basic channels in my scanner, I just don't know how to get the bands...it's a 30 channel 10 band Uniden BC handheld.
Bill B
Jun 10, 2010 | Uniden BC60XLT Handheld Scanner
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Frequency Coverage:
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Manual for Bearcat Scanner BC 140 10 channel
Nov 06, 2009 | Uniden BC248CLT Base Scanner
Need a free printable user manual for Bearcat scnner BC142XL
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Sep 06, 2009 | Uniden BC-95 XLT Scanner
Need a starter frequency guide
Aug 11, 2009 | Uniden BC60XLT Handheld Scanner
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
Turn off power, hold down the 2, 9 & L/O buttons while turning the power back on.
Aug 09, 2008 | Uniden BC60XLT Handheld Scanner
Uniden BC248CLT Base Scanner Logo
139 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
