Question about Vehicle Parts & Accessories
How do i change the oil pump on a 97 gmc 5.7 - Vehicle Parts & Accessories
    Master:
  • 710 Answers
Remove the oil pan, loosen the oil pump bolts, remove the oil pump, install new pump, replace pan gasket, install pan.
Posted on Sep 01, 2014
Oil pump on 05 gmc 1500
it's in the oil pan usually .
Mar 21, 2016 | 2005 GMC Sierra 1500 Hybrid
How do I fix and 97 GMC 1/2 ton with a 350 vortec. Runs great once running. Sat for 5 years. If sits more than 5 minutes wont start without shot of starer fluid
have you changed the fuel filter and emptied the gas tank and put fresh gas in? Stale gas will not start as well as fresh gas and there could be water from condensation in the tank.
Mar 29, 2015 | 1997 GMC Sierra
97 GMC JIMMY OIL PRESSURE DROPS WHEN STOPPED
This is usually caused by wear on the main bearings. To be sure it is actually dropping need to check with a manual gauge if so you can replace the main crankshaft bearings and while in there replace oil pump as you will have it off.
Oct 13, 2011 | 1994 GMC Jimmy
I have a 97 GMC Sierra 4x4 , manual 5 speed how do i identify, so the correct oil can be used
best thing to do is call local dealer and give them vin # and they should be able to tell you
Oct 09, 2011 | 1997 GMC Sierra
I have a 97 jimmy. my oil pressure drops when i stop and i have oil in it.its not low
Sounds like a cloggoed oil pump screen or a bad oil pump. I would flush the engine with engine oil fluch (can be purchased at any local parts store) change the oil and filter and see if the problem goes away. If not, you may need to invest in replacing the oil pump to prevent serious engine damage. Good luck
Feb 11, 2011 | 1997 GMC Jimmy
I have a 97 gmc sonoma and replaced the fuel pump and have no power now to pump. I found the test wire on truck and ran a test through the relay and worked, but pump still does not work. I have changed out...
It really helps if you post which engine you have and the 8th VIN digit. I ASSUME its a V6??? You should have 12 volts for 2 seconds on the gray wire (at the pump) when you turn the key on, If not, check the ECM/BATT fuse #9 20 amps, in the dash fuse panel. IF you do have power, then the relay is working and that is ok, If it does have power to the gray wire, then shuts off after 2 seconds thats normal. NOW while its running the fuel pump gets power THROUGH the OIL PRESSURE SWITCH. So get it running with your test wire, then disconnect your test wire. If it stalls out, then the oil pressure switch is either bad or disconnected.
Aug 30, 2010 | 1997 GMC Sonoma
97 GMC Safari. It is taking a long time to start. cranks and cranks... about the 3rd or 4th attempt, it will start. This problem just happenend.. One minute it started on the turn of the key... then, this...
Replace the FUEL PUMP RELAY. Its located in the under hood relay center. This relay primes the pump with the key on, about 2 seconds, then the pump will not run until the engine has oil pressure, then the fuel pump is energized.
May 14, 2010 | 1997 GMC Safari
HOW DO I RESET THE CHANGE OIL LIGHT ONCE THE OIL
look in the manual......turn the ignition to the on position not starting it of course and then pump the gas petal 5 times then the light will blink a few times turn off then back on...problem solved
Jan 30, 2010 | 2002 GMC Yukon Denali
Change oil light
It's a nag lihgt to remind you to change the oil.
To reset the warning, turn your ignition key to on, but not start. Pump your gas pedal three times quickly and the light will disappear for another 3000 miles.
Nov 07, 2009 | 2002 GMC Envoy
Change oil light on how do i reset after i changeded oil on 2003 gmc 6 cyl.
turn the key to the on position and press the gas pedal to the floor 6 times in rapid succession. than start the trurck without turning the key off
Apr 12, 2009 | 2003 GMC Sierra
Vehicle Parts & Accessories Logo
53 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
