Question about GE GTWP1000MWW Washer
Gtwp1000mww water drips after wash cycle - GE GTWP1000MWW Washer
My washer will drip water back in the tub after complete washing is finished Why Help
If the water is dripping in from the area where it normally fills for a wash cycle, then you probably have a problem with the water valve. You can open them up to see if debris has made its way into the valve, but they normally are not real expensive and it may just be easier and less hassle to just replace the entire valve. Hope this helps!
Feb 18, 2015 | Maytag Washing Machines
Will agitate instead of fill
The pressure switch it broken of the pressure switch is clogged. Please contact me so I can help you.
Jan 02, 2014 | GE GTWP1000MWW Washer
Water leaks into my smartdrive 058 machine throught the wash cycle and when the machine is switched off.
you need a new water valve for the unit. The solenoid is getting stuck in the open position (at least partially) and allowing water to continue to come through even after the water valve is no longer energized. This can be caused by normal wear and tear or sediment from your pipes getting stuck in the valve. This is especially true if you have well water or have recently had any plumbing work done in your house like a new hot water heater or something like that installed.
Nov 16, 2012 | Fisher and Paykel Washing Machines
Water dripping 1/2 thru wash cycle
I'm just guessing here, but if those spots you mentioned are heater supports and the heaters come on during cycle # 6, then the heat may be deforming the seals so that they leak. It would appear that the fix is to replace those seals, but I would try to build up the outer area with silicon glue (clean the area with rubbing alcohol or acetone first) to see if it would hold the water first. It could be a fairly extensive process to replace the seals (if you can still buy them!). Hope this helps some!
Jan 16, 2010 | Washing Machines
Cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE GTWP1000MWW Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
