Xm radio problems
My 2004 GMC Sierra has factory XM radio. I have started developing an intermittent problem. The left channel of the system goes out and only plays on the right side. It is only when tuned to the XM bands. The FM/AM/CD/Cassette bands are fine. The problem is intermittent and seems to be effected by temperature and terrain. I can only assume that it is an input connection problem but where is the input for the XM system? Thanks
sTatiC00000L
  • 8 Answers
SOURCE: xm will not work
i understand that you're only getting preview channels..and had the radio for almost 3 years....yes, they might be correct that your radio was broken already...but, have you ever asked them to refresh the signal into your radio? If you want you can do it online at www.refresh.xmradio.com all you to do is to key in your 8-digit radio i.d(can be found on ch. 0) then click submit...it'll give u the activation instructions...that u need to follow faithfully..if this won't work..i'll get back to you next week..Godbless!
Posted on Sep 08, 2008
sTatiC00000L
  • 8 Answers
SOURCE: XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
sTatiC00000L
  • 8 Answers
SOURCE: MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Posted on Sep 28, 2008
  • 168 Answers
SOURCE: XM radio reception issues
If you have the magnetic antenna, check it for a little nick on the cable on the outside of the car where water might get in to it. A little water can short the ground and the antenna wire. You also can wash (with lots of water around where the antenna cable is) and see if it happens again, then you will know it not just the weather
Posted on Mar 06, 2009
SOURCE: Delphi Roady xt, cassette adapter problem
I was thinking how can I trick the cassette into keeping the cassette in there because every time I put it in, it just came right back out
This is what I did
Go and find a real cassette and cut out a little piece of the cassette tape and set that aside
Every cassette is different so find a way to attach tape from a real cassette to the cassette part of the cassette adapter
You need to attach the tape so it is flat over the head of the cassette just like in a real cassette, which is the part where the music is transferred, once u get it over the head the cassette deck will think it is a real cassette and it will stay in the deck, the tape doesn't even need to be perfectly flat like in a real cassette tape, it can be all messed up and it will still work but flatter is probably better, so you are just tricking the deck into believing that it is a real cassette, it worked for me and hopefully it will work for you, tell me how it works out
Posted on Mar 10, 2010
Charges and powers on okay. MP3 and display work,. satellite radio does not play . stuck on "loading.."
Leave your radio on for a while, it may be updating the channels. To force an update, press the "Left" arrow, and enter a channel number (it must be a channel that your are not subscribed to)
Try playing satellite radio while docking. If you were docked, try undocking it. Try a factory reset + erase and upgrade the software (XM's website). And, if none of that works then you will need to call XM for a replacement.
Jan 04, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
The radio on my 2010 Subaru WRX has A Sat button on the radio. How do I get an XM Tuner to activate this button?
Many/most of the original factory radios with the 'XM' button already have the tuner in them. While outside (not inside a garage or under trees) Press the "XM" button then see if you can get channel 1, or channel 247, or channel 0. Channel 1 is free previews, channel 247 is free weather, and Channel 0 is the serial number of the radio. IF you have these 3 channels then all you have to do is call 1-800-XM-RADIO with the serial number from channel zero. Leave the radio on channel 1 for 30 minutes after calling, and you should then be activated. Let me know if you have more questions.
Jul 17, 2010 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Cadillac 2006 SRX XM Radio will not activate
Get your subscription refunded. There is nothing wrong with your radio. if they can't make it work, don't pay them.
Aug 31, 2009 | 2005 Cadillac SRX
How do I get to channel 210? When I turn the knob on the radio (2009 Mercury Mariner) it goes from 194 to 0.
Channel 210 is MLB Home Plate, which is part of the "Best of XM" package. If you haven't subscribed to Best of XM, which costs extra on top of your Sirius base subscription, then you cannot receive that channel.
Additionally, only certain radios are "Best of XM" compatible.. The fact that your car is a 2009 model.. While I don't know what radio it has in it.. I would assume it is a newer model radio that does have Best of XM capabilities, so the problem is most likely that you do not have the Best of XM package.
http://www.sirius.com/bestofxm
May 03, 2009 | Sirius Satellite Radio Receiver
Can't get refresh signal to work for xm radio
to reset the radio - it must be removed from the dash and unplugged.
Be sure to write down any anti-theft codes if your radio requires them.
However - since your radio is getting the 2 channels - it is working properly. The problem lies in XM turning on your account.
Be sure to get the correct # off the radio... sometimes there is a transposition error with paperwork.
The number can be gotten by setting your radio to channel 0. This is your radio ID# required to activate the radio.
Your Radio is working fine - call XM and stay on the line until they activate your account.
I have a suspicion the number was written down improperly.
Be sure when you call that the car is on, and that it is tuned to station #1... also - it can take 15-20 minutes to activate - and must be left on for the duration to catch the activation signal that is sent out.
Here are the steps from XM to activate manually-
Get Your XM Radio Activated Online
Step1 Turn on your XM radio and tune it to channel 0. The display will read your XM radio's identification number. This number will include both letters and numbers. Write this number down and head to your computer.
Step2 Log onto the Internet and go to the XM radio website. A high speed connection to the Internet will make this go faster, but you can activate your XM radio online with dial up.
Step3 Click on the tab that says to activate a new XM radio. This will take you to a screen where you will enter your XM radio's identification number. Type this in.
Step4 Choose a screen name and password to make an account on the XM web site. The screen name should be something that you will easily remember. The password needs to be at least 7 characters long and include 1 capital letter, 1 lowercase letter, and 1 number.
Step5 Enter your personal information for the activation of your XM radio. This information will include your name, address, and email address. You will also need to choose which service plan you will want to purchase for your XM radio. Enter your credit card payment to finish purchasing your activation of your XM radio online.
Step6 Turn on your XM radio and tune it to channel 1. XM will send a signal out to your XM radio to activate it. You will need to leave the radio tuned to channel 1 for 15 to 20 minutes to activate it.
If you have additional questions or concerns - please ask me first before moving on to another expert.
Thanks for using FixYa!!
Apr 01, 2009 | XM Radio Audio Players & Recorders
2005 Honda CR-V won't go to XM radio.
"XM Ready" means that you have to have a satelite radio installed in order to have XM service. I went through this when buying my 2005 CR-V and thought that all I needed was to set up the service. If you have an XM receiver installed you can controll it on your Honda factory radio. It is very misleading.
Feb 28, 2009 | 2005 Honda CR-V
Delphi MyFI
I have the same problem, and only the same few channels are shown on the channel access screen and they all have + signs.
Aug 21, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
XM Loading Problem for Volkswagen
I had the same issue. I called XM multiple time to have the signal resent. I told them I was receiving the preview channels and nothing else. I asked them multiple times if it could be hardware issue and they said no. I took it to the dealer and they ran a test ($98) and determined that the unit had failed. They didn't charge me for the $800 unit, but they did charge me $300 for the installation. Its working fine now.
May 26, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
 Grubhead
Grubhead
