Question about Panasonic KXDT333 Phone
How do i change the extension no of a pahasonic phone kdxt333
How can I change the direction of incoming calls to various extensions?
Just a guess but maybe changing the connections for the lines on the switchboard. This may also change their numbers though.
Apr 10, 2015 | Panasonic KX-DT333-B Digital Phone
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
Need to change extension numbers
Guessing you mean add or change extension numbers under the buttons, since you don't "add" or change extension numbers on the phone. From your set, press program dial 99 and the button you want to program. then , dial 1+ ext number and press STORE.
Do that for all the buttons you want to change then pick up the handset and drop it back down to exit programming.
Apr 10, 2013 | Panasonic KX-T7433B Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Changing names for extensions on KX-T7667
How do I change the name on one extension please.
Sep 24, 2009 | Panasonic KX-T7730 Corded Phone
CHANGING PROGRAM OF EXTENSION
The only way to change what extension a phone is, is to move the plugs that go into the phone system around. Someone needs to move the plugs, you can not program this remotely, so you will need a tech on site.
Apr 15, 2009 | Avaya Corded Phone avaparp18d
Change extension name
System Admin access is available from any 7310 or higher model phone. You need a password and overlay..or a picture of what the buttons do in programming.
Carl
Jan 27, 2009 | NorStar T7316E Corded Phone
How to change extensions
If you can find the box that controls the phones you can unplug the phone there at the box and plug it into a different jack on the same controler box.
Jan 21, 2009 | Lucent Merlin Legend MLX-10D Phone
CHANGE OF PHONE NUMBER
You need to contact your system admin...
Dec 10, 2007 | Avaya 4610
Panasonic KXDT333   Phone Logo
49 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
