Apu tripac My condenser fan on my tripac shuts off after a few seconds. Sometimes it doesn't even come on. Can the condenser fan be bad? It turns freely. Thanks, JR
5 Suggested Answers
  • 31 Answers
SOURCE: WHIRLPOOL 2 TON CONDENSING UNIT
check wiring for condensor fan motor,make sure wire nuts and connections are tight,if still no luck then i'm afraid you have a bad condensor fan motor
Posted on Nov 16, 2008
  • 7 Answers
SOURCE: compressor fan cycles on and off .1986 carrier mo#38eh0363300l
If your compressor is working continously, you most likely have a hi/lo fan cut out switch. What is the temp outside? If the temp is not real hot, it's normal for hi/low cutouts to cycle. You may need to adjust the pressures of the hi/low cutout and will need guages.
Posted on Jun 26, 2009
  • 340 Answers
SOURCE: Ruud achiever 9 outside fan not working
u need fan motor
Posted on Jul 11, 2009
  • 141 Answers
SOURCE: Is it possible to jump start a thermo King Tripac
it should be if its mounted under the box or on front but your refrigreation compressor needs to be on the box not the truck
Posted on Apr 06, 2010
Carrier apu blows cold air for twenty seconds and fan quits engine keeps running and fan starts again but only blows cold air for another twenty seconds
Have you tried rebooting the system? Just turn off the breaker for a few minutes.If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 07, 2017 | Carrier Heating & Cooling
Carrier APU wont shut down and showing SP on screen?
Hi there I have seen this a few time's while working on them. The SP stand's for shore power. If you can't get APU to shut down remove the top inspection cover. There is a lever by the fuel solenoid you can push and hold and it will shut the APU down. Do you know if the APU is equipped with shore power? If not I had one do this to me after I power washed it off. If you remove the top cover on the APU on the back wall on the left had side there is a controller. This is called your APU controller. There are to plug's in controller. remove them and check the weather stripping on the plug. I have seen them leak and let moisture in there and it would cause the APU to do funky thing's. If not it's possibly a APU controller. I'd check them few thing's and if you still can't determine a problem get back with me and we can diagnose further.
Sep 21, 2013 | Carrier Air Conditioner Accessories...
I have a thermo king tripac and I'm having issues
Hi there, do you have the diesel fired heater unit? have you checked the inline filter and also the injector nozzle inside the burner, we had one come in that was slightly blocked and wouldn't fire up! i have a brand new complete heater unit if you need any parts.
Dec 03, 2012 | Cars & Trucks
PC won't stay on, doesn't make it past the boot up menu
the fan on the CPU working? Try a different power supply the one you have might be faulty
Nov 18, 2012 | HP Computers & Internet
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
Astrostart 2100 autostart will not work all the time
It would almost appear that your battery is weak. If the engine doesn't freely turn over the remote start will not work because it recognizes the problem. I would also hope that you plug in your block heater when it's really cold.
Feb 06, 2012 | Chrysler Town and Country Cars & Trucks
I've got an Acer Travelmate 292LMI. My problem is: the notebook starts (leds on) for only a few seconds (I can see the acer display that preceeds the boot) but immediately it is dead. Only the AC leds...
It could be an overheating CPU problem.
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Sep 06, 2011 | Acer TravelMate 292LMi Notebook
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
Looking for fan condenser relay for buick 1996
When you turn on your A/C does the compressor come on? Unless you have a heat pump or you have a newer A/C that has a control board in it you won't have a fan relay. The fan is powered by the contactor, when it is energized the fan and compressor will both come on. If the compressor comes on and the fan motor doesn't. Disconnect all the power. Try spinning the fan blade,if it spins freely the bearings are ok, if it doesn't stiff or drags even a little, then the bearings are bad and the motor needs replaced. Then check the capacitor, if it has a bulge or is swollen then the capacitor is bad and needs replaced. You sometimes can take it to your parts store and some of them will check it for you. Last with the power back on and the unit calling for cooling check the volts to the motor terminals if you have 230 volts and the capacitor is good, then the motor is bad and needs replaced, if you don't then you need to check the fuses at the disconnect or breaker.
May 31, 2010 | Heating & Cooling
Tempstar a/c condenser screeching noise
Could be the fan motor's bearings. Try turning the fan by hand to see if spins freely or is tight. If it's tight you can try oiling it but that may not work for long.
May 30, 2010 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
