Question about AM Auto Parts 2001 VW Passat Mass Air Flow Sensor for L4 1.8L Turbo Engine ID AWM
ISO9141 VW PASSAT CODE PROBLEMS
CAMSHAFT POSITION SENSOR
The engine turns but won't start, after no problems the day before
You should get a code reader to see if there are any OBD codes that are set. This problem is usually caused by the crank sensor
Mar 17, 2016 | Hyundai 2007 ELANTRA Electric Engine...
02 jetta battery goes down if sits more than 8 hours
You have a short in your system. It could be as simple as a light staying on somewhere in the car, ceiling, ashtray, rear reading lights, and the all time favorite the trunk light that tends to be the biggest culprit. Check in your cigarette lighter and charging ports, something may be in there causing this problem. When battery is charged and you shut off your car go around and check that all lights are out. When you open your trunk the light always comes on, but if you reach in and it's very hot (BE VERY CAREFUL HOT IF IT'S BEEN ON) . One bulb ON can kill the battery in a few hours. Also I forgot to ask did you have any work done to your car prior to this problem, there may be some pinched wires involved. GOOD LUCK FREIND.
Sep 29, 2014 | AM Auto Parts 2002 to 2005 VW Jetta Mass...
Renault scenic problems
there is one major prob with renault engine manegment system is the crankshaft position sensor when it goes faulty it can cause strange problems get it changed first its easy and inexpensive to replace. is the eml light on? if so the fault code may relate to a throttle body fault
Oct 21, 2017 | Accel 77135-1 GEN VII Throttle Boddy...
Check engine light
The PCV system in the 3.6 is a cyclonic separator (like a Dyson vacuum) integrated into the valve cover on the passenger side. It can get clogged, but it's rare.
Nov 08, 2013 | aFe 2006 Volkswagen Passat - 3.6L V6 - Air...
Temperature Coulant Sensor
Under hood, driver side, upper engine area, mounted in end of cylinder head
Jul 15, 2013 | AM Auto Parts 2006 VW Touareg Mass Air...
Code p1330
I would say the problem is with bad fuel or a bad knock sensor.
May 14, 2013 | AM Auto Parts 2000 VW Passat Mass Air Flow...
What hydraulic oil should i use for convertable top motor
You can use any hydraulic fluid. It is usually about the same as a 10 W oil
May 06, 2013 | AM Auto Parts 1996 to 1999 VW Cabrio Mass...
AM Auto Parts 2001 VW Passat Mass Air Flow Sensor for L4 1.8L Turbo Engine ID AWM Logo
Top AM Auto Parts Air Purifiers Experts
David Payne
David Payne
ray gallant
Are you an AM Auto Parts Air Purifier Expert? Answer questions, earn points and help others
