Question about Minn Kota DeckhandTm 40 Anchor Winch
Need wireing diagram
Does red wire from motor go to J4 conector
Need of wiring diagram for driver's side window switches, or description of wires (colors) and placement on switches, on an 85 Carrera Thanks
Hello there
if you are replacing the switches the colors are as this
tho bottom conectors--red left-brown right-
The red is also goin to the t top connector
middle connectors --blue-black left--- blue-white right
top connector is only one and it is red (an extension from bottom red wire)
this should help you
trubka@yahoo.com
trubka
Oct 28, 2010 | 1984 Porsche 911
Puttransmission in blazer 4wheel drive need
autozone sites has free diagrams,look online. or go to a napa store and theyll print for you. that sensor is the only 2 wire plug in the trans harness. it should be on the output of the transfer case
Aug 24, 2009 | 2000 Chevrolet Blazer
Need to plug wires back in
RED on J4-1,2
BLK on J4-3
YEL on J4-4,5
May 26, 2009 | Mackie SWA1501 Subwoofer
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
DT 125 R will not start
Just to eliminate the most-obvious; you have checked for continuity/power through the killswitch on the right bar, and for all your fuses,yes
Nov 10, 2008 | 2004 Yamaha DT 125 R
Brake light wiring diagram 1972 Gremlin
I have a 72 amx, the two wire conector at the brake light switch down on the brake pedal is light green and pink and the plastic connector is brown and plugs into the switch at the top of the brake pedal.
May 21, 2008 | 1983 AMC American Motors Concord
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
CDX-M610 CD Player
Constant 12 volt is yellow,switched 12volt is red. Mix these two up and you'll lose your presets everytime you turn your car off. Ground is black. Sony uses gray,green,white, and I think purple for the speaker wires. You'll have green and green with a stripe going to one speaker and so on. Check out Sony.com, you can print off wiring diagrams that are model specific...
Mar 18, 2008 | Sony CDX-M610 CD Player
Minn Kota DeckhandTm 40 Anchor Winch Logo
35 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
