Question about Canon i80 InkJet Printer
I80 Remove case
Hi, my canon i80 printer wont feed paper through
There is only one solution to the problem with the i80. Here it is: there is nothing jammed. This problem is the result of the top of the printer being pushed down, effectively crushing the paper feed path by a sixteenth of an inch, right at the center of the machine. Likely this is the result of being carried in a travel bag full of other stuff, like the power supply, or from things being placed to rest on top of the printer. The solution is to open the two top covers, to grasp the main steel bar that runs the entire width of the printer with a pair of long-nosed pliers and to simply apply upward pressure. This will, in turn, lift a black plastic paper guide that has been pushed down into the path of the paper by the slightly bent metal. The printer will happily feed paper after this relatively simple fix. Mark the problem up to bad industrial design (though the mechanisms of the printer are otherwise ingeniously well thought out).
Sep 16, 2010 | Canon i80 InkJet Printer
It falshes orange and it makes a raddling noise
This error is cauded when there is a issue with the waste ink tank, which in your case will have to be resetted. To do the same please follow the steps as provided in the below article:
http://tricks-collections.com/waste-ink-tank-full-reset-canon-i80/
Also you can visit the cannon website and it tells you in detail the meaning/resolution when the orange light flashes:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i80#ServiceAndSupport
Fo to section "Services and support" and there in the dialog bos type "orange light flshes and it will give you steps to follow.
Please let me know if you need any further information.
Jul 21, 2010 | Canon i80 InkJet Printer
Printer wont recognise new cartridge
try to remove the ink cartridge. then turn off the printer with lacking cartridge. Now after 30 seconds turn the printer back on and it will ask you for the lacking cartridge. Now install it.
Dec 28, 2009 | Canon i80 InkJet Printer
My i80 canon printer not printing in black ink only in color. what is the problem? Rebecca
I think you have to check the settings on your printer, maybe it is set to print color alone, so you need to change it to print both black and color.
you can equally remove the black cartridge ink and clean the surface, maybe it is stock with dirt,
I wish you best of luck
Dec 22, 2009 | Canon i80 InkJet Printer
Black doesn't print well
printer doesn't give print out, all the maintenance has been tride but desn't give print out.
Apr 06, 2009 | Canon i80 InkJet Printer
Cannot find information on waste ink absorber for Canon i80
The waste ink absorber collects any spilt in from the head and stops it leaking out or sitting in the bottom of the printer casing. The printer is telling you that the one in yours in nearly full. You know have two options:
1. Replace the waste ink absorbers and reset the counter (will require taking the printer apart)
2. Reset the counter only (you run the risk of ink leaking out)
The waste ink absorber for the I80 can be got quite cheaply if you google about.
You can reset the counter by:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press
the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power
and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights
alternately in either orange or green, starting with orange.) During initialization, the LED blinks in
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times.
Hope that helps
Nov 16, 2008 | Canon i80 InkJet Printer
Installing canon i80 printer
If you have an old driver installed, remove it from your computer.
Visit a canon site , look for the download tab, enter your printertype and Operating system, look for your driver and download it.
After installation of the new driver : good luck :-)
Feb 17, 2008 | Canon i80 InkJet Printer
Canon i80
Install the drivers... here is the link:
Remove the printer.. install the drivers, then plug in the printer to the PC and power it on.
http://www.techspot.com/drivers/driver/file/information/8861/
Jan 11, 2008 | Canon i80 InkJet Printer
Canon i80 InkJet Printer Logo
44 people viewed this question
old marine
old marine
