Question about Frigidaire AEQ7000ES Dryer
Error code e52 on frigidare dryer what could be wrong?
Dryer not heating
That error code is a motor fault.
Oct 11, 2014 | Electrolux Dryers
Error E52 on frigidaire affinity
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Aug 06, 2014 | Frigidaire Affinity Series FASE7073LA...
Aeg lavatherm 57830 error code E50, what does it meann
E51 - Motor power triac short-circuited.
E52 - Intervention of motor overheating safety cut-out.
E53 - Motor triac "sensing" circuit faulty.
E54 - Motor inoperational.
Dado
Apr 23, 2014 | AEG T57800 Electric Dryer
I need error code for my 91 cadillac sedan de ville error code e52 .?????
Code E52 means the computer memory has been reset, usually because the battery has been disconnected or the computer has lost power.
May 15, 2013 | Cars & Trucks
Frigidare dryer aeq6000es2 doesn't spin, humming noise, burning smell
Hello tancrbtt - It sounds like your unit may have one or more problems. Either the belt slipped off the idle pulley and/or dryer belt and needs replacing, a faulty motor or a common failure between control and motor. Consult a professional to accurately diagnosis the dryer and to assist with the repairs.
Feb 12, 2013 | Frigidaire Electric Dryer
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 09, 2012 | Frigidaire Electric Dryer
Error code 52, Dryer won't start
You have a motor error. Remove any load from dryer and check if drum turns freely by hand. Check L1 power supply voltage, motorwindings, and motor thermal protector (if motor thermal protector has tripped,it may take up to 30 minutes to reset). If error persist, replace the motor with this new one.
Oct 15, 2012 | Dryers
Electrolux E52 error code Dryer
Hello drew_wedemey -Typically error code E52 indicates that the unit has a faulty motor. If the drum does not turn freely by hand, then I highly suggest contacting a professional to accurately diagnose the following; motor windings, L1 power supply voltage and the motor thermal protector.
Sep 30, 2012 | Electrolux Dryers
ERROR CODE E64 FOR FRIGIDAIRE AFFINITY
Please CALL Frigidare. We have had the same problem with our dryer and now the washer quit! Our set is only 3 years old! With all of the problems reported on the Internet there should be a recall on this set! They need to be informed! I am highly disappointed in the short lifespan of the Affinity Washer and Dryer. Dont know if I would purchase this brand ever again!
Mar 02, 2012 | Electrolux EIED55H Dryer
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly...
that's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
http://forum.appliancepartspros.com/dryer-repair/143380-frigidare-affinity-dryer-e68-error-code.html
Apr 06, 2011 | Dryers
Dryers Logo
24 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
