Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
How to reset sequence for Kitchenaid drawer dishwasher
4 Suggested Answers
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
rickead1
  • 1998 Answers
SOURCE: kitchenaid dishwasher KUDD01DPPA0 lower drawer has
hello, this is the schematic for your entire machine in case you ever do need it http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDD01DPPA0/0593/0130000?pathTaken=&prst=0&shdMod=KUDD01DPPA0 in your manual it would say what the start stop badge means If this unit is new do not attempt to repair the unit as it would be warrantied and you would void your warranty and I think it is still warrantied seeing how there is no manual online available yet if your unit is not warrantied and you require further diagnosis please message me back and I will look further into your situation Thanks Rick
p.s the stop badge could mean you have a blockage in your drain area but need clarification on your warranty information first Thanks again Rick
Posted on May 19, 2011
Daniel S
  • 4323 Answers
SOURCE: kitchenaid dishwasher kuds24sewh2. Have done
Hi
If the drain pump is clean and the water inlet valve is fine then the issue is with the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 22, 2011
MOD KUDDODPPA O THE CENTER LIGHTS ON BOTH DRAWERS FLASH RED
What drawers are you talking about on a kitchenaid dishwasher?
May 10, 2015 | KitchenAid Dishwashers
Replace check valve kitchenaid dual drawer dishwasher
look under the sink for the valve its huge an inline with the waste tube
if not then its here
https://www.youtube.com/watch?v=rOio5HaWeFU
Aug 17, 2014 | KitchenAid KUDD03DTSS DUAL DRAWER...
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
Dishwasher clean light will not stop flashing preventing further input and dishwashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Clean light blinks 7 times and will not start it is a STATUS KITCHENAID
Kevin
Dec 10, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Our kitchenaid drawer type dishwasher is open the locked light is on and we can not get it to clear or run
switch it of and leave for say 10mins and switch back on and see if it resets,if not push and hold the on/off button for about 30 secounds it should reset if not then the drawer switch is broken and needs replaced.adrian,,,,,,
Aug 20, 2010 | KitchenAid Dishwashers
Kitchenaid dishwasher mdl: kud101t jbt0
try the reset button sequence.. described in that other post about the clean light blinking.. that will reset the whole machine..
tpug
Jul 07, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Clean Light Flashes
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
143 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
