Question about Sony Cybershot DSCW350 Digital Camera
Problem with Sony Cybershot DSCW350 Digital Camera The mode selection button does not work properly. everytime i try to take a picture it keeps flipping between camera and video mode
SOURCE: sony cybershot camera DSC-P100 Digital
I don't have a repair manual but I can fix your LCD if you got one. If you don't have LCD, I got one to replace. Let me know what you would like to do. Thanks.
Posted on Jun 09, 2007
zohail
  • 1223 Answers
SOURCE: No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Posted on May 05, 2009
ginko
  • 19396 Answers
SOURCE: Can't import pictures from my sony cybershot dcsw70 camera
Try replacing the data cable.
Try replacing the Pro Duo Memory stick, or use a card reader to test the memory card.
Test the camera on a different USB port, and then on a different computer.
This can tell you if the problem is the computer or the camera.
If the problem is the camera , then the USB data port may be defective.
If the problem is computer, try doing a system restore to a date before problem started.
If that does not help you may need to reinstall the system.
Posted on May 16, 2009
SOURCE: Sony Cybershot camera will no longer take
I had the same problem. I looked at FixYa some months back and found the solution. Give the camera a jolt against something hard. . . has worked for me several times.
Posted on May 24, 2009
darntoothysa
  • 489 Answers
SOURCE: SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Posted on Mar 17, 2010
Keeps turning off
that is the normal thing when the batteries or contacts are faulty. If you changed batteries make sure they are an approved type and that all batteries are the same brand.Check the internal contacts in the battery compartment
Nov 09, 2013 | Sony Cybershot DSCW350 Digital Camera
How to switch language on japanese to english bought sony cybershot dsc w350 ?
put the camera in play mode as in your viewing a pic. Push the menu button go right to the bottom and you see a toolbox select this and the second option down is language settings ... tada.....bobs ya uncle :@)
Nov 14, 2012 | Sony Cyber-shot DSC-W350 14.1MP Digital...
I own a Sony Cybershot DSCW350 and when I put my sony memory card in, the camera on/off button, settings buttons, and shutter button stop working completely and the lcd portion is the only part that stays...
You might try to re clean the card with a smooth cloth that is used for cleaning DVD`s also clean the slot on your camera... sounds like you might have got something on the card or in the camera slot.. you can also trying cleaning them with a little rubbing alcohol.. not much.. let them dry.very good then re clean them with the smooth cloth.. if this doesn't work you might be able to get your pictures by tacking them to a photo shop and see if your card is bad.. This happens if the memory card is a small storage card.. I have had this happen to me.. Hope this helps you. T.
Jun 21, 2011 | Sony Cybershot DSCW350 Digital Camera
Sony Cybershot DSCW350 - Camera got dropped with the lens out. While I was able to straighten it out, the lens will no longer completely close (although it clicks like it is trying to) and I continue to...
It seems that some small part inside the lens is broken and prevents moving. Usually not fixable by user :-( I am afraid you will need help of service personnel.
Jun 19, 2011 | Sony Cybershot DSCW350 Digital Camera
How to change the language to english.thank you
Press the MENU button, select Settings (toolbox item), select Main Settings (wrench and hammer icon), then select Language Setting (the second item on the menu).
May 25, 2011 | Sony Cybershot DSCW350 Digital Camera
My sony cybershot dsc-w350 keeps turning itself on and off and reads system error
The system error is displayed in the Camera when there is some internal malfunction or when the Lens in the Camera get stuck.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
If the issue persists, service may be required.
Thanks for using FixYa
KenSolutions
Dec 05, 2010 | Sony Cybershot DSCW350 Digital Camera
Sony disital camera DSC-W35 driver free download
Check for details in the sony website: http://www.sony.co.us/productcategory/cybershot-digital-camera.
See the link to your model and search. Or call up the nearest call centre near your location
Sep 02, 2010 | Sony Cybershot DSCW350 Digital Camera
Where can I get the original hard copy instructions for my camera
The only way to officially get a hard copy is to call sony support at
1-239-768-7547 (U.S. only)
International (Calling from outside the U.S.): 1-239-768-7676
Hours: Mon-Fri 9:00AM-8:00PM ET
Regards.
Jul 27, 2010 | Sony Cybershot DSCW350 Digital Camera
How do I playback video on sony cybershot on the camera itself
Near Mode Dial, there is Playback button, press it to view pictures.
Jan 11, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cybershot DSCW350 Digital Camera Logo
57 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
