Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
Where is the belt assembly for the konica 1690f
  • Konica Minolta Master
  • 6,696 Answers
Dos not have one
Posted on Dec 29, 2015
Please how do reset transfer unit unit on konica Minolta bizhub c-252
for reset belt unit you have to change one fuse.
You need a new 50-80 ma fuse.
Remove the belt from the machine, the fuse is in the left side of the belt, under the left handle.
Replace it with a good same fuse.
For detailed guide see the link below:
Konica Minolta Service Manual
Aug 06, 2016 | Konica Minolta bizhub Office Equipment &...
Hi I have a Konica Minolta C-550 I appear P. -21 code After I changed the UNIT appeared to me Code P. -5 What should I do
I am going to assume you replaced the Transfer belt and transfer roller. Since you did not state that in your input. You did replace both at the same time. Cleared the counter for the transfer roller in the service mode?. Anyway the code P-5 and P-21 have to do with the registration sensor located below the transfer belt. On the right side of the machine. Where the edge of the belt is and exposed below the belt and behind the large plastic part below the belt there are two sensors one to the front the other to the rear of the belt, again below the belt assembly. It will require you the expose the sensors clean them. Worse case have them replaced, or the Main board!!!!. Recommend you have a Konica Minolta tech come out and do this procedure. P-5 is the front sensor failure
Apr 05, 2015 | Konica Minolta Office Equipment & Supplies
How to clear error service call (16H)
Take belt out did you remove all the tape that KMBS applied. check the inst again. also reseat the belt properly.
May 13, 2014 | Konica Minolta magicolor 2500W Laser...
How to remove error code service call 16H
Did you remove all the shipping parts. or go a bad belt replace with new one
May 13, 2014 | Konica Minolta KONICA BR BIZHUB C10X 1-SD...
Error p 5 konica milnolta bizhub c450
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
Where is the fusion unit on a bizhub c353
right side of the machine open right side cover look inside the machine see the shiney belt, well right above that is big assemble, that is tthe fuser
Jan 28, 2014 | Konica Minolta bizhub C250 All-In-One...
How can I correct this: process error-belt clear by cover,i need help????? on my Konica/Minolta 1690mf
I think this is mechanical problem and you need to check and remove belt-related assembly part.
Thanks
Sep 20, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
WHERE IS THE TRANSFER UNIT LOCATED ON KONICA
Unit is in the right side cover. New one should have instructions with it, but I think you unlock a handle and swap, then lock handle again.
Apr 06, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
