Sharper Image Tsi-11 The Shaper Metal Detector Express Logo
A
Anonymous Posted on May 06, 2014
Have parts for TSI-11 Metal detector - Sharper Image Tsi-11 The Shaper Metal Detector Express
MY HOOVER IRON IS NOT PRODUCING STEAM. WANTED TO OPEN IT TO SEE IF THE NOZZLE IS NOT CLOGGED BUT CANT
Try soaking the metal part in limescale remover overnight and pour some in tank resevoir
Oct 14, 2018 • Irons
Where to download a Shaper Image TSI-11 Express owners manual?
Check online googling the make, model and series number to get the correct manual.
CHeers,
Embroidery Services
San Diego, CA
How do i clean this iron on the metal part
Try a very small amount of oven cleaner. Wipe it on with paper towel...don't spray on directly. Make sure the iron is cool. Check every so often to test a small area to see if it's helping.
Sep 27, 2013 • Irons
I need a Singer Profinish "Thread Tree" replaced. Where can i order one?
Here is a link to a parts supplier.
http://www.sewingpartsonline.com/singer-14CG754-serger-machine-parts.aspx
The part you describe is:
4 Thread Holder, Universal #412519
$25 plus shipping
Shark G 1435 11 won't turn on
Hi
Have the power cord replaced.
Feb 29, 2012 • Irons
3helpful
Panaonic NI-R73NR Iron suddenly stopped working. Uses a small PCB with OEG PCD-124D2M relay which produces a sound when shaken as if some metal item is moving inside. Can this PCB be entirely replaced? Is...
Okay, here's what fixed mine. But first, understand this is a $23 iron and it may not be worth your effort. I'm an engineer and like fixing things, and I hate throwing stuff into the landfill, so I took the time to repair mine. If you can use a screwdriver and are good at taking things apart (and putting them back together) this will take less than an hour. NOTE: I often make use of a digital camera while taking things apart. Take a picture of things as you go, so you can see how to put them back together later.
The problem is the switch is corroded, from oxidation or carbon buildup, or both. Getting to it is most of the trouble. Follow these instructions:
1. Unplug the iron (helpful hint for the simple-minded. Can't iron if you're dead.) Dump out any water that's in it.
2. Remove two phillips-head screws from bottom of cord winder at base of iron.
3. Pull cord winder housing away from iron to expose electrical wiring.
4. Remove the small gray insulator card from it's slot to expose the screws that attach all the wires.
5. A red, blue, and black wire go up into the handle and attach to the shut-off circuit board. Tug on them gently to slide the circuit board out of the handle, remembering which side is up.
6. There's a screw inside the handle. Look where the circuit card came out and you'll see it in there. Use a screwdriver to remove it. Now you can lift up on the back of the small curved cover where the steam and squirt buttons are, and it will come off. Don't lose the steam setting button, it may fall off.
7. Now you can see the water jet nozzle. Lift it out of the way to find a screw under there. Take that screw out. I call this screw #1 for a reason.
8. There are three screws in the back of the iron, near the wires. They hold the iron together. Left and right are like screw #1. Take them out. The other one is a machine screw that's in the center, going down into the base. Take it out.
9. You can now lift the plastic part of the iron up off the metal part and set it aside. On top of the black plastic where screw #1 went through, near the pointy end of the iron, there should be a small washer. Locate it and set it aside. You'll want to make sure it gets back where it belongs when you reassemble.
10. There is a lamp that turns on when the iron is heating. It has two fine bare wires, a copper one (on the right if the iron is lying flat and you're looking at the base), and a silver one to the left. Find the screw where the silver one attaches and loosen that screw. Gently pull that wire off the screw. Note the routing of that silver wire around the black plastic, including where the tube insulator on the wire lays-- you will need to put this back right later. Lift the lamp out and the silver wire so it's more or less sticking up in line with the screw where the copper wire attaches. This will facilitate the next step.
11. Separate the black plastic cover from the brass-colored metal iron base by lifting at the pointy end of the iron. The wires will try to hang you up in the back, but if you wiggle things just right you'll be able to get them mostly separated. The lamp will need to descend down through the black plastic where the wires go as you lift the plastic cover off. As you lift it off, look inside. You can see where the rotary switch is inside there.
12. So here's the deal: the rotary switch controls a thermostatic set of contacts. This means there's metal in there that bends as it gets hot; the hotter, the more it bends. This controls your iron's temperature. When it bends enough, it opens a set of "points", which are tiny cylindrical contacts at the bottom of the rotary switch mechanism. Put on your glasses and look under the mechanism as you rotate the rotary control and you'll see them click open and closed. You need to clean them.
13. Get a small strip of fine sandpaper (400 grit or finer), about 1/4" wide and 2" long. Turn the control until the points are open and slip the sandpaper in between them. Now turn the switch the other way to get the points to close on the sandpaper. Pull the sandpaper back and forth between the points; that'll clean the contact on the gritty side of the paper. Now open the points again, pull the sandpaper out, flip it over, put it back in, and close the points. Now another few pulls on the paper to clean the other contact.
14.Remove the sandpaper. Put the iron back together in reverse order. Some things to watch out for: When you put the black plastic part back down onto the metal iron base, you'll need to make sure the wires and the lamp go the right way. You also need to make sure that the grey rubber grommet that lets water from the plastic tank down into the heated elements is properly pushed up through the hole in the black plastic. If you have trouble seating the black plastic onto the metal iron base, it's probably because that grommet is stuck halfway through the hole. Make sure you put the steam selector button back where it goes before you put the curved cover onto the top of the plastic tank. Getting the screw up through the hollow handle and into the hole it goes into can be tricky. I held the phillips screwdriver point-up and set the screw on top. Then I held the iron point-up and slowly put the screw up through the handle and into the hole. This might take a couple of tries; be patient-- you'll get it. Be sure to put the circuit card back into the handle the right way. Finally, be VERY SURE to route the lamp wires through the plastic parts correctly, and also make sure that you have correctly routed the red, blue, and black wires from the circuit card correctly before you re-install the cord winder housing.
Ironed on synthetic fabric by mistake and fabric melted on the iron soleplate. How can we clean it off? Please Help! Thank you
You could turn the iron on again - set to cotton or highest setting and allow it to completely burn off. Do this outdoors or well ventilated area indoors (no smoke detectors on!)
Or, you could warm the iron and use a plastic putty knife to scrape as much material from the iron as possible. A metal knife will scratch and mar the surface. When cool, use a scotchbrite pad to buff away remaining deposits on the iron.
Electric shock when iron is On
If it was not giving you shocks before you relaced the thermal cutoff fuse open it back up and make sure none of the leads to the fuse are touching any part of the metal chassy as this would allow line current to pass to all the metal of the iron. If this is not the problem the heating element is defective and it is shunting line voltage to the irons surface. If this is the case you can either replace the heating element... Or wear a rubber glove,Just kidding. Hope this was helpful,
George
Iron does not heat
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Top Sharper Image Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sharper Image Iron Expert? Answer questions, earn points and help others
