Question about Sharp EL-1701C Calculator
What does P.E mean and how to shut off
When adding on machine P.E shows up on display and machine stops working
WHAT DOES CODE AD MEAN ON THE DRYER
If your dryer is set to "auto dry" the display will show AD initially and then may show a number which is the estimated time for the clothes to dry in auto dry mode. The display may also show CD (Cool Down) and DN (Done) during the cycle.
Feb 27, 2015 | Washing Machines
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
My top loading machine always stops on Rinse
Did you find a solution? Mine is doing the exact same thing : ( Thanks.
Mar 22, 2010 | Samsung SW62ASP Top Load Washer
Displaying IE fault code
This is an inlet error. Shut the water valves off and remove the hoses one at a time. Shine a flashlite in to where the hose screws into the machine. Check the filter screens in there for any type of debris. Yiu can remove these filter screens with needle nose pliers. Once they are cleaned and re-installed, try it again. If is still showing an error, you have a connection/valve/or control problem.
Jan 13, 2010 | LG WD-1045FH Front Load Washer
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Saeco royal espresso machine
Ventilate just means that the system has senced a lack of water flow and shut down. Push the button to have water come out the wand and that should reprime the unit. If however no water comes out and the message stays on then you have another problem If water does come out but the message stays on then you have another problem. If in either of these cases you should google "saeco repair" and send it to an authorized saeco repair center to have it fixed.
Aug 26, 2007 | Saeco Royal Professional Espresso Machine
Sharp EL-1701C Calculator Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
