Question about Directv D11 DTV Receiver
D11 dtv searching for signal - Directv D11 DTV Receiver
Direct tv reciever keeps flashing when plugged in.
Probably a power supply problem. Have you tried switching off at the mains for a few minutes?
Mar 25, 2014 | Directv D11 DTV Receiver
I have no cable how do i program this tv set?
I assume you also have no satelite dish. You are probably on an antenna (or rabbit ears). If you don't already have one, you need a DTV Digital to Analog converter box. I am assuming you want to snag broadcast signals from the air, like in the good old days before the massive digital conversion of most broadcast stations. Might be hard to find one in retail stores, but start with WalMart or Best Buy, and if that fails you might check eBay (I think it is too late to get the government rebate which absorbed almost the entire cost of the box, but you might check around on Google searching on 'DTV Digital Analog Rebate'). The DTV converter will change the digital signal now being broadcast on most stations to an analog signal that your antenna connection will recognize. Without a signal, you can't program the channels because the tuner has nothing to latch onto. After getting a signal you just follow instructions for your TV to search for channels -- if you don't have instructions you might have to play around with the menus on-screen until you find what you need, but essentially it will be obvious when you see it ... the on-screen instruction will say something like select or program channels, and may let you choose manally or search automatically (choose automatically after hooking in the DTV converter to find all channels). Hope I understood your problem, your description is a bit vague.
Aug 29, 2011 | Televison & Video
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I cant watch tv because i have a receiver identification problem and i need help... i have'nt watched tv in 3 days
That error is usually caused from switching an access card from one reciever to another, if that is not the case then you will have to call directv for them to send a new authorization
Jan 16, 2011 | Directv D11 DTV Receiver
Remote codes
the 4220 does have SAT code 1377 on board, and will work with the following Directv sat receiver models: D10, D11, R15, H10, H20, and HR20.
Try code: SAT1377
What address is the D10 set to, DTV (00001) or AV1/AV2 (00002)? SAT code 1377 is for receivers set to white remote native code 00001.
to blink back the code on the white remote:
1. dtv
2. press and hold MUTE & SELECT for two blinks
3. enter 9-9-0
4. press #1 key, it won't blink because the numeral is zero
5. press #2 key, same as a above, zero blinks
6. press #3 key, zero blinks
7, press #4 key, zero blinks
8. press #5 key, this should be 1 or 2 or 3 blinks
Mar 31, 2010 | One For All URC4220 Remote Control
My directv D11 receiver continuously resets itself every few seconds, how can I fix this? I have reset it via the reset button several times and it makes no difference at all.
Unplug the box from the electrical outlet and wait 30 seconds. Plug the unit back in. If the problem persists, you have a faulty unit.
Feb 15, 2010 | Directv D11 DTV Receiver
Remote contol will not work
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
directv remotes are not guaranteed to work w/ all types of TV's. when programming remote to TV, make sure you are holding down MUTE and SELECT both at the same time for about 4-5 seconds. until it blinks twice at the top of the remote. also the slide switch must be under the "tv" mode on the right hand side. the website i provided is by directv, and has a list of their codes for the brand of tv that you have.
if you are trying to program a remote to a directv box, and none of the codes are working for the directv box, contact directv to have them send you a new remote.
Jan 22, 2009 | Directv D11 DTV Receiver
Directv d-10
take out the access card and push back in. and then restart the receiver
Jan 12, 2009 | Directv D11 DTV Receiver
Password
Directv says the only way to UNLOCK PASSWORD is to call them give them your account .box ID and ascess ID.They will unlock box by satillite signal .
Aug 28, 2008 | Directv D11 DTV Receiver
TV CHANELS
this is an activation or signal issue, you will need to contact direct tv
Jul 08, 2008 | Directv D11 DTV Receiver
Open Questions:
Directv D11 DTV Receiver Logo
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
