Question about Samsung BlackJack II Smartphone
Can't connect my blackjack 2 thru bluetooth to my computer
The problem is that, when I'm trying to pair the phone with the PC, the PC asks for a password. I'm setting the password to 0000, then the phone asks for the password as well. I'm typing the same password as I did on the PC, the the laptop tells me that the connection has successfully finished, but the phone is still processing the connection. After 3-4 seconds, the laptop tells me that the phone has been disconnected from the PC and on the same time, the phone tells me that the phone has been connected to the PC but it's not connected. I tried so many times to do this, but the results are the same. I would appreciate if you would give me a piece of advise about this matter. Please send me your answer at the e-mail address that I have provided bellow. Thank you very much in advance and have a great day
SOURCE: How I can connect internet to my laptop using my samsung blackjack
Plug your phone in through the usb port and have the sync programmed installed, then on your phone go to start, applications, file explorer, and then go to the windows folder and search for something called internet sharing and then open it and then tell it to connect....i believe you have to pay for the internet on your phone service...but after you do all that it should work -mitch- wraith0564109@yahoo.com
Posted on Sep 23, 2007
SOURCE: Blackjack data connections
go to menu in the internet explorer, click on tools, click options,click connections. unck the box that says auto detect settings and make sure your connection type is WAP Network
Posted on Jun 27, 2008
  • 3 Answers
SOURCE: Motorola H500 not able to connect to Vista
I had the same problem w my Compaq Presario V3000 HP BT module. I installed the HP Bluetooth drivers from hp.com and that fixed it. So instead of using Vista's built in stack, try one that your manufacturer may have issued.
Pim from the Computer People
Helping Kiwis go places
Ph. +64210398346
Posted on Aug 18, 2008
SOURCE: Data Connections
Did you upgrade your phone to WM6?
I had loads of issues with this until I found the answer on Cingular's forum. Make sure that under Settings > GPRS you have Media Net selected and not the AT&T one.
There's also this link http://www.blackjackusers.com/ which is full of usfull info.
Posted on Oct 12, 2008
SOURCE: h200 bluetooth
You should try 0000 four zeros thats the universal passcode.
Posted on Oct 31, 2008
How to download music from computer to the cell phone not having installation disc to install hardware/software?I have accessed www.htc.com and WWWWildfireForum.combut just cannt find a solution. ( I am 86...
Hi Frank try to transfer those songs from your computer with the use of USB or pair the device with the bluetooth:
USB:- connect your phone with the USB to the charging port, once device is detected try to move files (your computer will ask you anyway which disc/or device would you like to transfer them?
Bluetooth: you have to add pair your phone to your computer first by adding device to your bluetooth in you pc.. once your phone is added to paired devices you'll find an option to "send files to your phone"
feel free to comment back should you need further clarification how to do it. thnx
Aug 21, 2011 | HTC Wildfire Cell Phone
Tip
Bluetooth Connection Guide Part 1
This is a "How To" for Connecting the Nokia Series 60 device (Nokia 7650, 6600, 3650, 3660 etc...) via Bluetooth TM with the Windows Widcomm software used by TDK, Billington, MSI and others Bluetooth USB Vendors. The steps are similar for other Series 60 devices and have been checked with the 3650 and 6600.
1.Pairing the computer and the Series 60 Handset
Pairing is the process of swapping pass keys and setting up a trusted connection between the Bluetooth USB adapter / card connected to the PC and the 7650 handset. Save any files and close any applications you may have been working on.
2. Set up Bluetooth TM on the 7650 by going to the Main Menu, selecting Connect and then Bluetooth.
3. Make sure the Bluetooth option is On and My Phone's Visibility is Shown to all. Remember what is in My Bluetooth Name - or edit it to one of your choice - this is what your 7650 will be seen as by other Bluetooth TM devices.
4. Right Click on the Bluetooth Icon in the system tray, on the menu that appears go to Setup and then click on Security.
5. A window appears and all being well the right hand pane will have your 7650 (titled what ever you have entered into the phone's My Bluetooth Name entry). If nothing appears click Refresh and your phone should then appear. Highlight the 7650 and click Execute Pairing.
6. A window will pop up asking for a PassKey. Enter in a numeric only passkey and click OK.
7. On the 7650 a screen pops up asking you to enter a passkey - key in the same number you just typed into the PC.
8. By default any connections from your PC to the 7650 must be manually accepted on the 7650. You have an option to set up a connection from the PC to your 7650 as authorized, this means when you connect from the PC to the phone it won't ask you if it's ok and will connect automatically.
9. To set it as automatic: On the 7650 in the Bluetooth TM Setting Screen, you joystick right to the Paired Devices screen, highlight the Computer you just paired with and press Options, select Set as Authorized and Yes. You will then see a padlock icon beside the paired device - this device will no longer require manual authorization for connections to the 7650.
Now you should set My phone's visibility to Hidden - so that unknown devices searching won't see your phone. You can still be connected to by any paired devices. Remember to switch it to Visible if you want to pair with a new device or receive a file / business card from someone with an unpaired device.
on Mar 06, 2010 | Cell Phones
Hi, My Samsung mobile is GT-C3303. I have problems in connecting to the bluetooth device on my laptop machine to transfer the music files. I have tried both 0000 and 9999 and 1234 but nothing is helping...
you have to pair your samsung phone to your laptop first before you can start sending and receiving files through bluetooth.
an option is, turn the bluetooth on your laptop on, then the bluetooth of your mobile phone on. on your phone, search for devices, then once you see the name of the bluetooth device of your laptop, tap it then choose connect or pair, you will be asked for a passkey (you can input anything try 0) or in some devices wait until a pop screen appears which will contain the passkey usually 5 to 6 digits. then click ok
another option is (i tried this using my samsung corby wifi and a samsung n150 laptop and it works just fine) make sure that the bluetooth on your laptop and phorne is turned on. on your laptop click on the bluetooth icon or click the file you want to send, then right click, then choose send to bluetooth, your laptop will then search for available devices, just choose your mobile phone then automatically there is a popscreen which has a passkey, then click ok. on your phone you will be asked to allow to connect thru the laptop, just click ok, then make sure that the passkey matches between your phone and laptop. (usually it is automatic, you just need to click ok) you should be able to send and receive files thru bluetooth on your phone and laptop
Apr 20, 2011 | Samsung Star GT-S5233 Cell Phone
How do i connect my phone to my computer
There are two ways you can connect your phone to your computer.
1) Using the cable which connect one end to the phone and another end which connect to the USB
port of your computer. After connecting the phone, you can see your phone, by visiting My
Computer. Your phone will be listed in harddrive portion
2) The other way is to connect your phone using bluetooth technology, for this to happen your pone
must have Bluetooth technology as well as with your computer. If your computer and phone
both has bluetooth technology,
a) Turn on bluetooth device on your phone as well as your computer. Then from your computer,
you can discover your phone. After searching most computers will give a code to put in the
cell phone to pair. Enter the code and computer will pair with your cell phone
Try your luck!! :)
Apr 03, 2011 | Samsung Cell Phones
Need to transfer files to mac
You can follow this steps for your concern: Via Memory Card 1. Remove the memory card slot cover, located on the right side of the unit. 2. Insert a microSD memory card into the memory card slot until it locks in place 2. On the SGH-i607, navigate to the folder that contains the image 3. Highlight the desired image 4. Press the right soft key for Menu 5. Select Edit (4) 6. Select Copy (2) 7. Navigate to the Storage Card using the up or down navigation keys. 8. Press the left soft key for Select.to copy the image to the memory card Via Bluetooth On the SGH-i607 1. While in standby mode, turn Bluetooth on 2. Switch the Bluetooth visibility to On On the PC 1. Connect the Bluetooth adaptor to the PC?s USB port 2. Search for Bluetooth devices 3. Select the device to pair with the PC 4. Exchange PIN code(s) on both the PC & handset to pair devices (default pass code is ?0000?) 5. Using My Bluetooth Places, select File Transfer or OBEX to view the phone?s contents 6. Copy the desired Photo file 7. Paste the file in a PC destination
Feb 02, 2010 | Samsung Blackjack SGH-I607 Smartphone
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Jabra VBT2050 headset won't pair with blackjack II
ARE U FOLLOWING THE CORRECT PAIRING PROCEDURE
pls follow this
ok here u go first turn on the bluetooth func in ur mobile, now while ur bluetooth headset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the phone bluetooth config ur headset will come up like JABRA VBT2050 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try any call u will hear it in ur headset
pls rate me fixya for this if it helped
Jan 13, 2009 | Motorola Mobility H350 Wireless Headset
Bluetooth conection
Make sure You have a Bluetooth device on your laptop[of course that is necessary].Now i recommend you to use WIDCOM bluetooth software.It is theeee best for bluetooth device handling.
Also make sure that the bluetooth device on your samsung blackjack is working.That can be done by asking your friend having a bluetooth enable phone to search for your mobile via bluetooth,be sure you turn on your bluetooth device on your mobile and make it visible to others.
Make sure after intalling the software (WIDCOM) the drivers are successfully intalled.Then pair it with your mobile.So simple isn't it
Please rate me my name is Karatela
Dec 01, 2007 | Toshiba Satellite A105 Notebook
Samsung BlackJack II Smartphone Logo
187 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
