Question about Jandy Aqualink Rs4 One Touch Control System Control System
Can not use two aux , gfic trips - Jandy Aqualink Rs4 One Touch Control System Control System
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Go into set up system assign aux 2 to what you want it to do
Posted on Dec 01, 2014
Whirlpool front loader keeps tripping fuse when turned on
Either a dead short or you you are using a ground fault circuit breaker.
gfic Google Search
Sep 28, 2014 | Washing Machines
Candy grando keeps tripping electric and door security light flashing
Just a suggestion and that's to see if it's tripping a GFIC circuit, if so it would be on the load side and by pigtailing it in front of the line side you would eliminate the problem.
Jun 26, 2014 | Washing Machines
Florescent ceiling light on the garage ceiling will not go on
If the GFIC trips all outlets wired from it will lose power also. Check your wiring. You should also remove switches from the circuit containing outlets.
Dec 04, 2013 | Dryers
Honda generator eb4000x gfic tripping
if you are using a lead that has a active , a neutral and a ground wire in the lead , there is no real reason to ground the gen set itself
the neutral will not be bonded to the frame as that would create a possible short during operation
the circuit is simple --active is the power wire --neutral is the return wire from the applications and the ground wire is for dead shorts and to prevent electrocution
Sep 09, 2017 | Honda Electrical Supplies
Hot tub trips gfci
spa may be leaking water internally check to see all grounds are hooked up . or you might have a bad gfic
Sep 06, 2012 | Qca Spas Pool & Spa
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
The breaker on my air condition unit keeps tripping as soon as it is plugged in thanks jeff
I ASSUME IT'S THE GFIC TYPE PLUG AND ITS WHATS TRIPPING ?. IT COULD BE BAD, SOO WHAT YOU CAN DO IS REPLACE THE PLUG WITH A STANDARD PLUG, JUST FOR TESTING ... YA KNOW .. HOPE I WAS OF HELP .. JAY
Jul 21, 2011 | Frigidaire FAX052P7 Compact Room Air...
My maytag stainless microwave keeps tripping the gfic. I'll reset it and the control panel will work fan,light,etc. If you open door it will trip or try to start it will cause it to trip. Help!!!!
Hi, There is an internal short or very high amp. draw....this is what is kicking the gfci
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 28, 2011 | Microwave Ovens
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
Jandy Aqualink Rs4 One Touch Control System Control System Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
