Question about Florida Heat Pump 2 ton for geothermal application
How to repair broken inlet water fitting?
Water fitting is broken off flush with unit surface.
Ice maker is leaking water.
hi John.
Troubleshooting an Ice Maker That Leaks
When troubleshooting ice maker there are a lot of different things to be aware of. Ice makers are very useful when working correctly, however if there are any problems, it's important to fix these as quickly as possible. One common problem with ice makers is that they can leak. A leaking ice maker can be a result of a number of different reasons.
You will need to put your detective's cap on in order to inspect and diagnose what is actually causing the problem with your ice maker.
Checking Your Refrigerator For the ice maker to work properly it needs to be perfectly level. If it isn't level, this can cause leakage.
Before leveling the freezer you should unplug it so that you can work on it safely. Check that the freezer is perfectly level by placing a spirit level on top of the freezer from side to side. The leveling feet can then be adjusted by twisting them to raise and lower them. Continue this until the freezer is aligned properly from left to right.
Then repeat the process by putting your spirit level from front to back to ensure the freezer is completely level.
Ice Maker Level The ice maker unit itself can also be leveled. This is inside the unit and can be repositioned if needed. Loosen the mounting screws and align the ice maker unit so that it is perfectly level. After leveling, ensure that the mounting screws are tightened to prevent the ice maker from moving.
Water Supply Line The water supply line could also be damaged or broken. This is the tube that is behind your freezer. It's a fairly strong tube and is susceptible to damage. Check that the pipe isn't pinched or kinked.
Fill Cup When water enters your freezer it will be put into the fill cup. This is a funnel that directs the water into the ice cube molds. If this isn't aligned correctly, it can cause problems with leaks.
If you see any ice forming on the fill cup, this could be because the valve is not working properly.
Inlet Switch Remove the inlet switch and inspect it for signs of corrosion or damage. If any of the terminals have corroded, you will need to replace them. Using a multimeter, you can check that the switch is working properly. Press the switch and check that it connects and reduces the resistance as it should.
Inlet Valve If you are testing the inlet valve, you must first disconnect the power so it's safe to work on your freezer. The inlet valve is located in the bottom of the freezer. Turn the water off at the source and then disconnect the supply line. Use a bucket to catch all of the water from inside the inlet valve.
Label the location of all the wires and disconnect them. You will also need to remove the inlet supply tubes. Using a multimeter, check the resistance of the coil. Also inspect the mechanical functioning of the inlet valve, as it can fail mechanically as well as electronically.
After following this troubleshooting guide for your ice maker that leaks will get you back in business. Now you can enjoy a cold beverage for your hard work!
Comments Troubleshooting an Ice Maker: Ice Tastes Bad
Shares
When troubleshooting ice makers there are a number of steps that you can take to find the cause of the problem and put it right. One common problem is when the ice doesn't taste right. If the ice tastes bad, then there can be a number of reasons for this.
When working out why the ice tastes bad there are several things that you will need to consider. The problem could also be caused by one or more of the factors that could make solving it slightly move complicated.
Washing the Ice Bin The ice bin is the container that stores the ice, if this becomes dirty or moldy it can make the ice taste nasty. Simply taking the ice bin out of the freezer and then washing it will solve the problem. Read the instruction manual to find out where the ice bin is located.
Unscrew or unclip the ice bin and then wash it in warm soapy water. Dry the ice bin and then reassemble it. Place it back into the fridge and then find out whether it has resolved the problem.
Old Food If there is any old food in your refrigerator, it should be removed. The ice could taste funny because of this food. Empty your refrigerator of any old food and wash all of the shelves so that the fridge is completely clean.
Once the old food has been removed and the fridge has been cleaned completely you should then test the ice maker to find out whether the problems still affect you.
Flushing the Supply Line The supply line carries water to the ice maker. Sometimes the water can become stale, which is why you might be able to cure the problem by flushing the water pipe out with fresh clean water.
Test the ice maker after flushing the supply line to ensure that the water is now clean that the ice doesn't taste bad.
Water Inlet Valve If the water inlet valve is damaged, then this could also be because of the water inlet valve. If the water inlet valve is damaged or broken, it can leave the water exposed to smells inside your fridge, which can make the ice taste bad.
The water inlet valve will need replacing if it is damaged or broken. By replacing this water inlet valve you will be able to correct the problem and enjoy better tasting ice.
Replacing the Water Filter There is a water filter inside of your fridges ice maker that is designed to remove particles and bad smells from the water. The water filter needs to be removed and replaced.
The water filter should be replaced with the same type and model suitable for your freezer. Use your freezers model to ensure that the correct filter is fitted.
Supply Line Filter If your fridge doesn't already have a supply line filter, then fitting one could greatly help to reduce problems with the ice tasting bad. These can be fitted to virtually any ice maker.
Now you should be in good shape thanks to this troubleshooting guide for an ice maker that was producing bad tasting ice. It's time to reward yourself with a cold beverage.
Dec 08, 2017 | Refrigerators
Tip
How to install a new flush valve
  • Flush valves are held to the tank by one large jam nut on the bottom of the tank. Installing a new flush valve usually requires removing the toilet tank from the bowl, which can be rather complicated. However, wall-mounted tanks may not need to be removed.
  • If the toilet tank must be removed, turn the water off completely, flush the toilet and hold the trip lever down to evacuate most of the tank water. Use a sponge to remove the remaining water. Disconnect the tank's inlet fitting from the water supply. If the flexible riser tube is damaged, replace it.
  • Then, unscrew the two rubber-gasketed bolts flanking the flush valve. These bolts go through the tank and bowl flange, with nuts beneath. Use caution–forcing the bolts may cause you to break the tank, bowl or both. Use plenty of penetrating oil on the threads. If they still won't budge without force, try wrapping masking tape around a hacksaw blade and sawing with the teeth facing you, so the blade cuts on the "pull" stroke. The layer of masking tape will protect the bowl's glazed surface from saw scratches.
  • The tank should now lift away from the bowl. Lay it upside-down on a throw rug or newspaper padding to protect it, and unscrew the large nut holding the flush valve to the tank. Use channel-locking pliers plus penetrating oil and extreme care to avoid breakage. Clamp a well-padded locking plier/wrench around the flush valve to keep it from rotating inside the tank.
  • Install the new flush valve according to the directions. The rubber gasket goes on the inside of the tank to prevent leakage. The flat washer fits on the outside to prevent tank damage.
  • Use new brass tank hold-down bolts, which will remain workable. Tighten the bolts just enough to compress the tank's soft rubber gasket and keep it from leaking.
  • Install the water supply riser to the tank and turn on the water.
on Jan 16, 2010 | Plumbing
Heirloom imperial oval dual flush cascade outlet blue centre yellow float after flushing contiues to run overflowing into bowl how to adjust inlet valve float
Bend the rod down slightly and gently. Suspect the float has a leak - empty water from toilet and gently shake float to determine if there is any loose water inside and if so, empty and let surface dry overnight, then put a little silicone glue like aquarium cement over the hole where the water came out.
Apr 25, 2017 | Home
My flush has stuck on, how can this be sorted.?
Close the Inlet Water valve to the Flush Tank.
Remove the lid on top of the Tank cover.
Check the link/chord connecting the flush knob and the Flush valve.
It might be broken.
Normally the Flush Tank lever, which is outside the Tank lifts the Flush valve at the bottom of the Tank.
Nov 14, 2014 | Sport & Outdoor - Others
Im trying to flush the cooling system on a '97
Not positive about that engine, but the usual method is the heater inlet will come off the cylinder head somewhere and to the firewall, and the heater outlet (the return hose) will be at same place on the firewall and go to the water pump, very close or at the fitting where the lower radiator hose attaches to the water pump inlet.
Jul 21, 2013 | Cars & Trucks
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Despite fitting a new washer kit to an old style caroma dual flush/float system stop valve..water is still seeping into tank....even if i plug the inlet nozzle with my finger which yu would think would be...
I suppose you're talking about a toilet. One likely issue is the flapper valve ( if this has one). If no flapper then check whatever sealing mechanism is used to prevent water from entering the bowl when idle. Clean the sealing surfaces good. Make certain they are properly aligned.
Sep 01, 2017 | Caroma 270W-RF Reflection Round Front...
I have a Duravit Starck 2 toilet cistern which is approximately 5 yrs old, recently water from the cistern runs constantly into the bowl. I have renewed the flush value without any success. I would...
Did you replace the flush valve or the flapper?
There must either be a problem with the seal between the two surfaces of the flapper and flush valve or the flapper is being prevented by the flush system to returning to make a seal against the flush valve after the water completes draining during the flush cycle or more likely water is draining through the overflow tube.
Make sure the sealing surfaces are clean and not damaged.
Make sure the flapper is not being interfered with and is able to return to the closed position to make a complete seal against the flush valve.
Check adjustment of the water fill level to make sure the water is not filling above the water overflow. If the inlet valve does not shut-off when the level is adjusted to the proper level the water inlet valve may need replacing.
The following videos may prove helpful.
Dec 22, 2010 | Home
Water heater makes bubbling sound
If your tank is very old than there might be accumulation of rust and debris on bottom of tank, try and purge the tank put a garden hose on the lower most water fitting at the bottom of your unit and drain the tank. Be sure to shut off the water inlet. You might even have the booklet still taped to the side of your unit and it will explain how to flush your unit.You might also want tot think about replacing your anode rod it is probably toast if old unit.
Nov 20, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water leak from turboflush saniflo
water inlet pipe blows off when toilet is flushed
Nov 11, 2008 | Saniflo 013/005/007 Sanibest Toilet with...
Florida Heat Pump 2 ton for geothermal application Logo
70 people viewed this question
Top Florida Heat Pump Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Florida Heat Pump Health and Beauty Expert? Answer questions, earn points and help others
