Question about Fuji FinePix S700 Digital Camera
Images saved to internal memory how do I download to my pc?
    Novelist:
  • 109 Answers
Use the supplied cable that came with the camera and also the program that came with the camera to download pics to your PC. Change the setting in the camera as to where the pics are stored (internal memory or memory card) and then use a card reader (Aptiva $9.95 at Staples) to put the memory card in and then plug into a USB port and download that way. Or you can still use the cable. If this has been helpful, please rate it accordingly. Thanks and good luck.
Posted on Jul 10, 2009
bmwrider
  • 215 Answers
SOURCE: Can I move images saved to the internal memory to the optional xD-Picture Card
You sure can. Go to your shooting mode menu. Scroll down to BACKUP Click on OK Select YES Click on OK All image data stored in the internal memory is copied to the card. Press MENU to exit the menu. Make sure there is enough room on your card to hold all the pictures in memory. When you've copied to the card the original pictures are still held in the internal memory so you will have to clear it. When the card has insufficient memory, [CARD FULL] is displayed and copying is canceled. When the battery icon is blinking, pictures cannot be backed up because of insufficient battery power. If the battery power runs out during copying, the image data may be lost or damaged. I recommended you use the AC adapter if you have one. If not, make sure your batteries are charged. Never open the battery compartment/card cover, remove the batteries, or connect or disconnect the AC adapter during copying as this may cause malfunction to the internal memory or the card.
Posted on May 21, 2006
SOURCE: Transferring images on camera memery onto memory card.
I had the same problem, and I found after much playing and mostly accidental findings that I could do this by following these steps
1. Put an SD card in the camera. Will not work otherwise
2. Go into playback mode, where you view the pictures, button looks like an blue arrow pointing to the right
3. Press the round 4 way controller downwards, and a menu (that I have never seen before!) appears
4. Choose the 4th icon along on the top line and that will give you options to transfer from memory card to camera and the other way around.
Posted on May 13, 2008
  • 7 Answers
SOURCE: my camera says "images recorded to internal memory"
pdf user manual is available for free on Fujifilm site, http://www.fujifilm.com/products/digital_cameras/z/finepix_z20fd/pdf/index/finepix_z20fd_manual_01.pdf
You should either :
- connect your camera directly to the PC with provided USB cable, after recognition of the camera by the computer (may take some time), you will see the camera like a disk in the file explorer, and have two different folders representing internal memory and the removable memory card, just browse in the directorys and you will find the picture.
- or send the picture by infrared, see pages 56 of your user manual (probably not the simplest way, as the comuter may not accept infrared transmition).
- or use the cameras menu to transfer the pictures from internal memory to removable memory. You must enter picture displaying mode, the presse menu, you have an "copy" option to transfer between internal memory and memory card, see page 76 from user manual. Then you just get the card out and read it as you ever do.
Hope this will help.
Posted on Jun 22, 2009
  • 11967 Answers
SOURCE: I can't find the images in my internal memory
In the setup menu, there should be an entry for something like "copy" which would permit you to copy the internal memory images to the memory card.
Posted on Sep 30, 2009
SOURCE: Casio Exilim EX-Z2. I can't save images to the memory card.
same thing happens to me
i hope someone could help us.. i think the problem is the camera, because i try the sd card on another device and it works fine :s
Posted on Dec 06, 2010
How do I save to my internal memory of my digital photo frame ?
Usually, the camera saves to internal memory when no card is present. Internal memory is not large. More for holding a photo or two until you realize there is no card there. When you do save to internal memory you then need to transfer the images to a card, or plug your camera into the computer and transfer the images that way. Hope that helps.
Oct 18, 2014 | Cameras
Internal memory card full
Hello, You need to either download the images to your PC or delete the images from the internal memory or you need to install a blank memory card in the slot and save images to that card.
Best Regards, Russell
Dec 17, 2012 | Kodak EasyShare C613 Digital Camera
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
Internal memory
You can only access the internal memory, when there is no card in the camera. So, turn off the camera, remove the card, connect to the computer and save the images to the computer. After checking that images are saved, you can delete the images in the internal memory, before inserting the card again.
May 04, 2010 | Fuji Finepix Z20fd Digital Camera
I need to know how to download the internal memory photos on my hp computer. It has HP Media Smart.
These are read/view only images and cannot be transfered.Except your question is not well defined.
Dec 27, 2009 | Kodak EasyShare CX7430 Digital Camera
How do I access the internal memory? I believe
If you take the memory card out of the camera, you can go to playback and see exactly what's on the internal memory. If you see the images you are searching for, re-install the memory card and go to playback, again. You won't be able to see the internal memory any more. Press the menu button and go to the copy function. You will have the option to save images from the internal memory, to the card, and vice-versa. Save them from internal to card memory and you should have all the images saved from your camera to the card, for easier access to them.
May 18, 2009 | Fuji FinePix Z10fd Digital Camera
Move images saved to the internal memory to the optional xD-Picture Card
The images saved to the internal memory can be copied to the xD-Picture Card, but you cannot copy images from the xD-Picture Card to the internal memory.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Saved images to the internal memory or to the optional xD-Picture Card
The internal memory and the xD-Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD-Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
Move images to the internal memory to the optional xD-Picture Card?
The images saved to the internal memory can be copied to the memory card, but you cannot copy images from the memory card to the internal memory.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Saved images
The internal memory and the xD Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Fuji FinePix S700 Digital Camera Logo
88 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
