Question about Westinghouse Refrigerators
Adjusting fridge door - Westinghouse Refrigerators
Adjust door on kenmore 22
Your Fridge need be leveled and door need be adjusted after fridge is leveled
Dec 06, 2013 | Kenmore Refrigerators
Leveling a refridgerator
if not level you need to tip it back and unscrew or screw in the feet on it. use a 2ft level on top to be sure which way to go. if just the door, open door and there is a bracket in between the freezer and fridge and it should be adjustable a little bit. unscrew til lose adjust door to right spot and hold while tightening bolts. that should work. if the fridge door is on top and freezer is on bottom then adjust bracket screws on top of fridge.
Jun 24, 2012 | Stainless Cal Flame Refridgerator Steel...
I have a Northland freezer/fridge side by side unit. Model # NM118. The door on the refrigerator side is not properly aligned with respect to the door on the fridge side. The refrigerator side door is...
Start by making sure the box is square -- that the doors are perfectly parallel across the top, with respect to the outside of the box. You fix that problem by adjusting the front feet on the fridge to square up the box. If the doors are all square and the fridge door is still low, look for some adjustment in the bottom door bracket - may have some slots where you can loosen mounting screws and adjust upwards. This may take two people or a lever (maybe a piece of lumber) as you have to raise the door while you're making the adjustment. OR remove the top bracket, remove the door and set it aside then try adjusting the bottom bracket and replacing the door and top bracket.
Feb 28, 2018 | Northland Refrigerators
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
How to adjust doors so they will close
The doors them selves are not adjustable.
The fridge feet have to be adjusted so that the fridge leans backward. This will cause the doors to fall closed
Mar 30, 2011 | Refrigerators
My side by side fridge door does not close by itself when released
It is likely that your fridge is tilted left or right, and possibly forward at the same time. Most refrigerator doors will self-close if the fridge is slightly tilted both back and to the handle. The fridge is raised or lowered by adjusting the front feet or rollers.
The problem you'll encounter with a side-by-side fridge is that if you adjust for the right-hand door to self-close, there's a good chance that the left-hand door will want to stay or fully open; if you don't check it while making the adjustments. It can take a little extra time to make sure the adjustments make the front both perfectly level left to right, AND slightly higher in the front than the back.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Refrigerators
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
How to adjust fridge and freezer doors on Kelvinator C520 Litre
how do you adjust the freezer door on a Maytag side by side 26 cu ft refrigerator?
Apr 04, 2009 | Refrigerators
GE Side by Side Fridge Door Adjustment
Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
Jul 02, 2008 | GE Refrigerators
Refrigerators Logo
13 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
