Question about HP Officejet H470 InkJet Printer
Replace the sevice module - HP Officejet H470 InkJet Printer
My sevice 4x4 light comes on and there is no light on the switch
You must have the control module scanned for fault codes to see why it is on.
Jun 13, 2012 | Cars & Trucks
I get sevice code 234, what does it mean
234.(11101010) Phase 6 - Lid Lock Open Circuit Check Harness to Lid Lock and connections at the Motor Control Module and lid lock ends.
Primary Fault: Connector to the harness. Either end could be at fault.
Action: Replace Harness.
Secondary Source: Lid Lock has failed to be activated.
Action: Replace Lid Lock housing.
Tertiary Source: Motor Control Module has not responded to the Lid Lock being activated.
Action: Check the lid has a Tang and is fitted correctly to activate the Lid Lock. If this is all in order, the Motor Control Module must be at fault and needs to be replaced.
Sep 21, 2011 | Fisher and Paykel (IWL12)
2007 equinox chev read sevice traction stabilizer
That would be your computer system trying to tell you that there is a malfunction in your traction and stability control system. You will have to access the computer data in order to find out the nature of the failure and to diagnose the problem.
Apr 11, 2011 | 2007 Chevrolet Equinox LS New Cars
Dell XP 400 sevice codes 1 and 4 only
The “self test” on the monitor displays when not plugged into a computer. This means that it’s working. The LED error code 4 means the video subsystem has a problem. Either your video card is bad or bad memory module. Try reseating video card and/or memory.
Jul 07, 2009 | Dell XPS 200 PC Desktop
Call for sevice
Correction, you need to press "clear" and "8" simultaneuosly and hold to display error code...
Apr 13, 2009 | Toshiba Estudio 200L Copier
Looking for the Power Control Module, PCM, on 1996 F350 7.3L
The PCM will be to the right side of the steering column where it comes through the firewall as you look under the hood. there will be 2 wire looms, one is the back side of the fuse box and the other is the PCM.
Dec 29, 2008 | 1996 Ford F350 Crew Cab
Compac MP 1600
your prblem will be in motherboard or in power pack module-start to change powerpack module first then motherboard second- or pass it to good sevice center.
Dec 25, 2007 | Compaq MP1600 Multimedia Projector
HP Officejet H470 InkJet Printer Logo
Seeker5211
Seeker5211
