What could be causing the speaker on a vox vt80+ to sound blown, when separating the speaker from the amp it sounds fine & there seems to be no problem with the amp itself, what cuold be happening here?
  • 3,368 Answers
Probably vibration. Give the amp some time it probably will fail.
Posted on Nov 04, 2014
  • 31 Answers
SOURCE: NAD C370 Amplifier
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Posted on Sep 17, 2008
  • 24 Answers
SOURCE: Getting occasional popping sound through
Describe your system in greater detail. Does the preamp have a mechanical selector for the tuner/phono/CD or does it have a digital selector that you can operate with a remote? The problem might just be a dirty selector switch that need to be sprayed with Deoxit contact cleaner. It could also be bad cables so try swapping cables with the tuner.
Posted on Dec 28, 2008
MNfisherman
  • 11896 Answers
SOURCE: Blown fuse no sound in one channel
The only way this could happen is either the wires touching or a capacitor overheating and shorting out, Also hardly bumped or dropped would cause loose solder connections. Wich you should check eitherway
Posted on Feb 04, 2009
  • 133 Answers
SOURCE: scratching sound from right speaker connector
Try resoldering the speaker connector pins on the printed circuit board (if they actually are soldered to the board), there might be a loose solder contact, otherwise see if the connector is dirty and clean it if necessary.
If possible, check any other connectors and components for dirt and / or bad solder contacts and resolder if necessary.
Another quick thing is to check the relay which provides for the delayed speaker turn on - see if the relay contacts are dirty (brown, oxydized, kind of dark, burned color), if so, they need to be cleaned well with some fine sandpaper.
The relay (usually a black rectangular block about half the size of a matchbox) will usually have a plastic top cover which is snap mounted, if you can't remove the cover easily then it's better to desolder and remove the relay, open, clean and resolder it or even replace it with a new one. Some relays may have the top cover glued onto the housing in several spots which makes them more difficult to remove the cover and others still will be completely sealed with epoxy and therefore very difficult or impossible to open without damaging or ruining them.
Also, it could be something else, the above suggestions are just some of the possible causes and solutions.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Posted on Sep 16, 2009
  • 561 Answers
SOURCE: I have no sound coming from my amp a rotel rb 981
it is never advised to change wires while the amp is switched on. you may have blown your diodes on your post amp then you have a problem.
have you tried other speakers tested your speaker on another system to rule them out as OK?
if you open the case be careful not to touch any large capacitor as they may still be chared and can give you a nasty belt.
any fuses should be easy to find and to see if they are blown. ensure you get the same rate fuse when you replace. if you see any charing of diodes then i think repair may be costly. good luck.
Posted on Nov 12, 2009
When mic n headset is plugged into my motorola cp100 sound comes thru both radio speaker and headset. How do I fix this so that when the headset is plugged in. Sound only comes in thru the headset??
Sometimes on Motorola radios, the vox option get left on. Due to both vox and regular PTT option at the same time, may cause them to RX out of both speakers. So try turning off your vox option which should under menu on the keypad
Nov 09, 2015 | Motorola Radio Communications
Vox vt40+
that is because it is two different output channels. eventually you will blow the speaker or your amp. It wasn't designed to handle the impedance of an external speaker through the stereo
headphone jack. Are you sure that your speaker is hooked up or plugged in?
Mar 30, 2014 | VOX Amplification Vox VT40+ Valvetronix...
Vox valvetronic amplifier static crackle
Check the speaker for a loose dustcap or separated spider.
Nov 20, 2013 | Audio Players & Recorders
I Have a Uniden UH-015SX and everything seems to work fine except I have no sound coming out, I have tried plugging a speaker in and nothing from it nor the built in speaker. Any Ideas?
hey had the same problem with my 015sx no sound from internal or external speaker... long story short after much playing i found the VOX was on (whatever that is) i pushed the menu button and it showed VOX 8 i moved that till it was off and everthing came good
Jun 27, 2012 | Audio Players & Recorders
My guitar amp has power(Lights up),but no sound.Fuse was good,the one right by the power plug in.No blown capacitors or resistors.100 att vox 2 by 12''
Here is a link to Vox:http://www.voxamps.com/support/circuits/ Start by checking the wiring to the speakers and the speakers themselves.
Jul 19, 2010 | Music
Left speaker has developed a hum. Checked connections and all seems well. Sounds raspy like the speaker has blown.
This is likely due to a problem with the amplifier. You may have turned up the amp to the point of overdriving the speaker. The distortion at these high levels cause clipping and turn what was once crisp, clear sound into a muddied, garbled mess.
If the speaker is left connected to that source long enough, damage to the speaker and the amp may occur.
Without changing positions of the speakers: You can disconnect the affect Front or Rear L & R speakers and swap them (connect the L speaker to the R output of the amp and vice-versa). If the buzzing / hum "moves" to the other speaker, then the amplifier has the problem. If the buzzing / hum stays with the same speaker, the speaker has issues and is likely "blown".
Either way, it is probably not going to be a "cheap fix"
Jun 24, 2010 | Boston Acoustics VRS Micro Speaker
I Have a Gem Sound EVA3955 amp an TR-150 subs sub stop wroking
Yes and Yes. If bypassing that noise filter, has no effect your subs could have blown.
Jan 05, 2010 | Car Audio & Video
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
57 people viewed this question
 Grubhead
Grubhead
