Why does my washer just buzz when turned on - Washing Machines
Fridgeaire washer dryer stack unit. The washer side doesn't complete cycle.
check door lock switch if not water valve for cold side is not on or valve is defective buzzing sound from water valve means not opening
Jun 27, 2016 | Frigidaire Washing Machines
My washer buzzes when knob is pulled but it will spin just not fill or agitate
sounds to me like either the water faucet at the wall is shut off or their is some sort of restriction to the pipes not allowing the washer to fill
some on here may say that the buzzing will be the motor but since it spins i say bully to them the motor only knows to go to spin or agitate rotation based on on what the timer/control tells it to do if it will turn one direction it would turn the other direction as well. So definently check the water supply to the washer
Oh the buzzing is the solonoid on the valve opening the valve yet since no water coming in you hear the buzzing while you wouldnt hear it since it would be drowned out by the sound of the water coming in
Jul 19, 2011 | Washing Machines
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
My GE washer (mod WHSE5240D0WW) will not spin. It
sounds like the motor or the programer has packed up on you more (likley to be motor,) buzzing is the motor trying to turn but cannot,
Oct 26, 2009 | GE WHSE5240D Top Load Washer
I have a neptune washer that makes a buzzing type noise when I hit the start button? from motor area. The belt and pulley into the unit turns freely. I did get it to start and the barrel did rotate then...
The buzzing noise is probably an electrical relay that controls the motor. They have a spring assembly on an arm. When you energize it it creates a magnetic field and pull the arm down into contact and starts the current flow to the motor. If it's buzzing, the relay is probably bad and need replaced.
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool cabrio washer has stoped during the draining cycle and now just buzzes, can not turn off or get it to start back
sound like a stuck motor you should check it out and see if the motor turns these motors have cheap bushbearings that wearout once they waer out to a certain point the motor stator phisicaly touches the side of the motor and once magnetizm turns on it sticks to the side and buzzes but does not turn cuz its stuck!
Aug 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Buzz when changing cycles
there isnt, or at least shouldn't be a buzzer to let you know its changing cycles, only end of cycle. if its buzzing betwwen cylces theres problem a woudl assume eith timer( if theres a selector forit try turning of end of signal chime any way
Feb 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
