Question about Craftsman 4 Cycle Blower/Vac
Model 358 craftsman blower, where is the fuel filter
  • 25 Answers
Follow the fuel line from the tank to the carb. If it has one, its in that tubing line. There will prolly be a particle filter screen inside the tank to keep crud from getting to the carb. Other than that - there's really not much to the fuel system on these.
Posted on Jun 22, 2009
Replace a fuel line on a craftsman weedeater model#358-798271
Get foot of fuel line and insert into tank - bring it out and attach the filter - then draw it back it in with filter attached - cut off excess line and attach to carb input .
Sep 10, 2016 | Craftsman Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
How do i get to the fuel filter on an old sears blower model 358 797920,32cc
Sounds more like the carburetor needs to be cleaned or replaced. Dirt in carburetor will cause this problem.
Aug 29, 2012 | Craftsman Garden
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Unable to start my craftsman blower/vac model 358 797931
check your fuel filter, and make sure your gas is no older than 6 wks old. you may have a slug in your carb, you may have to clean your carb
Nov 14, 2011 | Garden
I'm looking for a replacement bag for my craftsman model 358798370 blower/vac. The zipper is shot and there is a hole in it. Any ideas ?
http://www.searspartsdirect.com/partsdirect/part-number/Craftsman-Parts/Leaf-blower-Parts/530402533/0071/358/Model-358798370/0247/1503110?keySuffixId=NA&productTypeId=x&searchModelNumber=358798370&subCompDesc=Replacement%20parts&brandDesc=CRAFTSMAN&modelDesc=BLOWER&blt=11
Oct 31, 2010 | Craftsman 4 Cycle Blower/Vac
2006 25cc 2 cycle craftsman leaf blower
The smaller line that has the fuel filer on it in the tank goes to the stem on the lower part. The larger line that just terminates shortly inside tank goes to the stem on the top of the carb with the bulb.
Nov 30, 2009 | Craftsman Garden
Need manual for craftsman blower/vac model 358 797290
if you googel searsparts open that link then put in your model number and look for the link that says need a manual for this clik on it and you can get it hope this helps you
Nov 06, 2009 | Craftsman Garden
This Model 358-797251 Leaf Blower will not start. What can I do to make the engine run at the regular speed?
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Oct 19, 2009 | Craftsman 4 Cycle Blower/Vac
Need bolts for carborator for gas leaf blower model #358
Hello. One way I found to get Craftsman parts is to order them online at the Craftsman website.
CYA, Gator241
Feb 06, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
990 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
