Question about Cycle Works Seat Cover Yamaha TTR125L TTR125 TTR 125L 125 L TT R125 08-12
Dirt bike When I pull in clutch and break to stop the bike shuts off. Is it the clutch or I I'm riding wrong. Just got it
When I start up my bike I pull in the clutch lever put it into gear the bike shuts off and lunges forward.
Clutch problem - please help - Dirt Rider Magazine
forum.dirtrider.com/discussion/6668452/clutch-problem-please.../p1
18 posts - ‎9 authors
I start the bike in neutral with the clutch pulled in, then I shift into first and it will kill ...bike, if you put the bike in gear and try to roll it (even with the clutch lever pulled ...Started it back up, gave it enough throttle to keep it from stalling, put it in 1st, ... I continue to change the oil in my clutch but almost immediately it turns white.
Re:Always shuts off putting it in first!! - Road Star Forum ...
roadstarclinic.com > Forum List > Technical Corner > Maintenance
Jun 17, 2014 - 10 posts - ‎8 authors
My 99 Roadstar has the habit of always shutting off when I knock it into first ... pull in the clutch and put it in first gear the bike lunges forward and shuts off. ... Hold thefront brake ALWAYS when shifting a cold bike into first. ... What I do on cold starts is to select first gear with the motor off, pull the clutch in and ...
How To: Fix 5 Common Bike Issues ' RideApart
https://rideapart.com/articles/fix-5-common-bike-issues
Jul 21, 2014 - It's easy to assume the worst when your bike isn't opperating perfectly, ...Where's my ignition! ... First, ensure the battery is good and that the engine turns over.... Try starting with the kickstand up, clutch in, and bike in neutral and see if the ...goes away most the time when the bike is put into gear or revved.
Checking Your Yamaha Ultramatic Drive Belt - YouTube
? 9:35
https://www.youtube.com/watch?v=vgh4TzSgCB0
Oct 9, 2010 - Uploaded by 6speeddakota .
Jan 19, 2016 | 2006 Yamaha Stratoliner S
Clutch not working
Hi Inge, not to worry steel plates got a little rust film from sitting probably. Let the bike warm up for a few minutes then do the push,run, jump on the seat routine while in nuetral and drop it in 1st gear and drive it around for a while the plates will eventually break free and peace on earth and good will to all mankind will prevail. Try using 20w50 Harley Davidson SYN 3 in the primary and next winter don't put the bike in storage with the engine hot. Wait untill the next day and fire it up drop it in gear for 30 seconds then put it away for winter storage. Good luck
Mar 01, 2014 | Harley Davidson FXSTD - FXSTDI Deuce...
Clutch problems
Release arm in engine is broke.
Jun 06, 2013 | 2003 kawasaki KX 125
How to drive?
you can ride the cluthch on a bike un like a car you wont hurt it its oil lubricated constantly, sitting on the bike pull the clutch in with your left hand and click the left foot lever down in to 1st, then learn how to click it back up 1 half movement in to neutral. the neutral light will come on sfter the bike enters neutral. in first gear give the throttle on the right hand a squeeze and pull the clutch in with your left hand put foot gear selector down in to 1 st and begin to release clutch slowly. hold on as bike will engage may be jerky balance yourself! when you get moving stop! by pulling the clutch in and the hand brake as you close the throttle to stop! practice your take off many times some where safe! when you get your balance in 1st gear pick up speed and begin shifting the foot gear selector up in to 2nd gear and practice closing the throttle and breaking to a safe stop. gears are generslly 1st down 1 click 2345 and6th all up from there and neutral is 1 half a click up from 1st between 2nd gear. And dont put it in gear with the kick stand down t may stall on you
hope this helps
May 03, 2011 | Honda CR 500 R Motorcycles
I just bought a 2006 zx14 that will only start with the kickstand up and the clutch pulled in. The neutral light is on but if you put the stand down the bike shuts off.
Both the clutch and the kickstand are safety features to stop people crashing.If the stand is down and hits to road while you are riding.You crash.The clutch is to stop people starting the bike in gear and losing control if it starts.Hope this helps you
Feb 13, 2011 | kawasaki ZX-14 Motorcycles
Clutch not engaging
could be a few different things,But always start with the small( inexpensive )first and work your way up...#1 check your clutch cable adjustment to be sure its engaging and disengaging properly(clutch cables stretch over time and need replaced or adjusted)...but if you have never done any clutch work to the bike(and you ride it like i do mine) #2. it probably needs new clutch plates and #3 maybe clutch basket from your description of the problem. the clutch plate fibers wear down over time(they are like brake pads and wear out).and the plates wear groves in the clutch basket and interfear with the plate movement...hopefully its just your cable..hope this helps..
Jul 30, 2010 | 2003 Suzuki RM 125
My atk 450mx stalls often
clutch cable needs adjusting its still engaging whilst when you stop by sounds get back to me if its wrong i have other optons
Oct 12, 2009 | 2005 ATK 450 Mx
2003 yz 125 clutch
This sounds like dirt and grit in the oil is causing the clutch to grab. Change the gearbox oil. Ride the bike for a couple of hours using the clutch often. Now drain the oil again and put in fresh oil. This will flush out the dirt and grit. Use 10w40 motor oil. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell. Do not use synthetics or oils with "special" additives.
Other possible causes are > a need to adjust the clutch lever for 1/4" free play at end of the lever > warped clutch plates or friction plates > Clutch has been worked on and assembled wrong > low oil level in the gearbox > frozen clutch hub bearing > Incorrect clutch cable being used.
Please post a comment after the double oil change. The 2x oil change is a cheap way to eliminate a possible cause and hey, it isn't gonna hurt anything. If you still have the problem I can help with a clutch rebuild.
Jun 04, 2009 | 2003 Yamaha YZ 125
When i pull the clutch on my dirt bike it doesn't spring back and when it's pulled the clutch doesn't engage.
First, get a new clutch cable. Tape the new cable to the old one and unhook the old one. Now you have a new cable and a reserve cable ready for use if needed during a race.
Second, change gearbox oil and install a new oil filter if your bike has one. All the dirt and grit in the oil is binding the clutch. Ride the bike for a couple of hours using the clutch often. Now drain the oil again and put in fresh oil. This will flush out the dirt and grit. Use 10w40 motor oil. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
May 02, 2009 | 2005 kawasaki KX 250
Cycle Works Seat Cover Yamaha TTR125L TTR125 TTR 125L 125 L TT R125 08-12 Logo
47 people viewed this question
Top Cycle Works Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Cycle Works Boating Expert? Answer questions, earn points and help others
