Question about Brother 60-Stitch Computerized Sewing Machine, CP6500 15029528
Why dosome stitches get skipped when doing regular stitching
night71
  • 328 Answers
SOURCE: upside down stitching
Sounds like the needle alignment is out.
This website has some instructions on how to properly set it up and also has manuals too.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=hf_cs8072eus&Cat=53
Posted on Nov 01, 2007
  • 201 Answers
SOURCE: Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Posted on May 03, 2009
Zenqi
  • 208 Answers
SOURCE: I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
Posted on Jul 11, 2009
SOURCE: how to adjust tension on bottom stitch?
There are tow places where the thread tension is adjusted.
One is bobbin. This is not routinely adjusted. Just once and it is good for long time. This is done by turning the only screw on bobbin by about 1/4 turn or so at a time. Try several settings until you find he best.
the other place is the conventionally on body of the machine.
Tension of bottom stitch or top stitch are very confusing words. meaning difft things to difft pple.
All i can say is this. If u see bottom stitch run straight through loops of top thread. then either top tension is too loose or bottom too tight. and vise versa.
With top tension set to middle position adjust the bobbin to get correct stitch. Then later on all u need is to adjust only the top setting according to stitch and cloth
Posted on Oct 17, 2009
SOURCE: my brother sewing machine, My
check needle to see if it's damaged-roll on flat surface to see if it roll correctly
adjust top & bottom tension according to operation manual
Posted on Oct 01, 2010
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Singer sewing machine is stitching every half inch how to fix this
I had a singer machine that had a basting stitch that was like that. Make sure that you have chosen regular straight stitch.
Feb 12, 2013 | Singer 2639
Can lint get up inside the shaft that raises and lowers the needle?
the needle bar is not hollow,
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
May 01, 2012 | Singer Confidence 7463 Computerized Sewing...
Brother 60-Stitch Computerized Sewing Machine, CP6500 15029528 Logo
13 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
