Question about Sharp Office Equipment & Supplies
Sharp AR 5320 printing a shadow copy
Sharp AR 5320 printing shadow images
    New Friend:
  • 91 Answers
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Posted on Jun 23, 2009
Sharp ar 5320 hwo to repair u4 200
check the duplexer which is what is used by the copier to print on the other side of the copy
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 07, 2014 | Sharp AR-5320 Black and White Copier
Dear All We want to but sharp Machine but we ...
5316 ,16 copy per minute
5320 , 20 copy per minute
May 20, 2010 | Sharp AR-5320 Black and White Copier
What difernt betwenn ar 5320 and 5320 e
The AR-5320 comes standard with XY Zoom and Dual Page
Copy Mode. The AR-5320E has additional image editing functions (Rotation Copy, Margin Shift, Edge/Centre Erase, and 2-in-1/4-in-1) available with the optional AR-EB7 upgrade and you can uprade the memory for printer with optional AR-SM5 256 Mb
Apr 27, 2009 | Sharp AR-5320 Black and White Copier
Problem with sharp ar 5320 copier
Sounds like a bad earth or loose connection. Try using the parrallel port instead, or take the panel off and look for bad connection
cheers
Nov 29, 2008 | Sharp AR-5320 Black and White Copier
It dosent enlarge the document in book copy mode in sharp ar 5320
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
Nov 15, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W Copier giving L 4 error msg alternatly
L4 is main motor drive overload. It could be a power problem going on with the copier. Are these copiers plugged into surge protectors?
If you can have a Sharp technician look at it, it would be a good idea to determine if the motor, power supply, or main board is the culprit.
Sep 21, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
NO PROBLAME JUST A QUESTION
That all depends on the amount of toner coverage on the copies you make? The companies gauge the number of copies per toner on only 6% coverage on each page. About one small paragraph, any more the less the yield. On average about 2k -2.5k per toner give or take.
Apr 29, 2008 | Sharp AR-5320 Black and White Copier
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
257 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
