Question about Schrade Blade Runner 912" 1430t Old Timer Knife
How to use a schrade honesteel knife
How do I use it? Which direction do I go and which object should be stationary
I have juki ddl 8500 7 and the thread cutter will not worked
Is it making a noise when you try to cut? Most common is that your needle plate is bent down and is preventing your knives from doing their job. In this case, you can take the plate off, turn it over on a flat surface and use a hammer to flatten it. While the plate is off, test your machine and see if the blades are now moving. Make sure to keep your fingers away while you are doing this. :)
Now check to make sure your feed dogs are not cracked or broken and keeping the blades from moving. Next: Sometimes you either get a ball of thread or a piece of a broken needle caught in the blades as they try to cut and it can either bend the stationary knife (this knife is in the general shape of a backwards letter L) or break it off. If all the knife pieces are there, the small moving knife (that looks like a little flat fat bird with a big eye :) ) becomes dull and won't cut the thread when it moves against the stationary knife. In either case, you can replace the knife. The most common is to replace the stationary knife. It is the easiest to replace and can be ordered online with the part # from your parts book. If you don't have a parts book, try to contact your online sewing parts company for the part.
Mar 20, 2016 | Juki Sewing Machines
Find the date of manufacture of a schrade uncle henry knife with the serial number y85309
I've put out some feelers on your question. If I get any more info. I will post it later.
Oct 15, 2014 | Washing Machines
Walkthrough pc games 'legends of the past'
why post this to hp computers.?
join a game forum?
Jun 30, 2017 | Video Game Consoles & Games
I can not get the blade out of my dewalt retractable utility knife dwht10046
Just take apart the knife and get knife out reassemble it and then put the knife back in
Nov 23, 2012 | Dewalt Tools & Hardware - Others
How to change knives
First, safety stuff: Make sure the jointer is unplugged and be very careful with the knives, they are quite sharp.
You should have enough room between the tables to get the knives out, if not remove the stationary, outfeed table. There are four hex-cap screws on each knife that hold the clamp bar on. Remove them with an allen wrench or hex driver if you have one and take the clamp bar and knife out. Pay attention to which way the bevel is on the knife so you put them back on the same way. If the blades have never been turned, they are double sided and can be turned around so the opposite side is out. The knife and clamp bar are designed to go on only the right way. Make sure you get the hex-bolts on very tight. Do the other knife, replace the table and make a couple test runs to check allignment.
Jan 27, 2012 | Delta Machinery Masonry Tools
When I take a picture of an object - like a knife or magazine book etc - there will be a glare on the picture either in the center or the bottom how do I stop that.??
I had this same problem. You can' t take the pic directly above it you have to angle your shot. Eventually I figured out that it was easier to shut off the flash and just use a secondary lighting source like a couple lamps.
Mar 28, 2011 | Nikon COOLPIX P4 Digital Camera
How to replace a stationary knife
What stationary knife are you referring to?
Nov 19, 2010 | SINGER 7470 Sewing Machine
How to open dell monitor cover model E207WFPc
Remove the Stand, Remove the 4 Screws from behind the spot where the stand connects to, then take a flat ended object such as a butter knife or a sharp knife, and unclip the black face. then the screen comes right apart, this solution is also the same for the 20xx-30xx Dell WFP Models.
Apr 14, 2010 | Dell E207WFP LCD Monitor
Noise
High probability that an object, that had escaped notice during loading of clothes, has been "tossed" over board the wash tub into the outer tub. Most washing machines are constructed this way (two tubs, one move-able, one stationary) to prevent this object toss, but somehow they still get tossed. Solution is to remove the object and methods vary from simple (use magnet snake retriever if object is magnetic) or use mechanical snake retriever (has tiny pliers at far end of wire) to extreme by removing inner tub.
Dec 24, 2007 | Admiral AW22 Top Load Washer
Schrade Blade Runner 912" 1430t Old Timer Knife Logo
367 people viewed this question
Top Schrade Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Schrade Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
