Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My Cub Cadet 2185 only runs about 10 minutes then dies. Engine area is very hot. I have cleaned everything very well and put in a new fuel filter. Fuel pump is working.
  • aronel1372 Jun 22, 2009
    Thank you for the advice, rscamaro73. The fuel line was close to the engine, so we moved it. We also just now purchased a new air cleaner at the Cub Cadet service center. The old one was very, very dirty. After we put on the new air cleaner, we will give the mower a try to see if there is any improvement. Will let you know.
    Thanks again.
  • 25 Answers
Inspect the inside of the fuel tank, where the fuel exits the tank. There might be dirt/crud clogging the line. Also, if the fuel line is too close to any exhaust pieces, or is against the engine, it will boil the fuel and cause it to vapor lock (and stall out). Look for these items and hopefully it will cure your issues. Also clean off all dried grass/dust from intake screens. Also check your oil level. Make sure its in the good range, not over or under filled.
Posted on Jun 22, 2009
  • rscamaro73 Jun 22, 2009
    I've got 2 different John Deere's I got stuck working on and trying to make them last as long as I can. So far its been belts, batteries, coils, blades, and your regular maintenance items as well. Did get some brake work done on the smaller one but the bigger one needs deck adjustment work and a new deck pulley. I've been playing with mowers for years....just getting back into it again. Some of these same things work the same for autos :) Hope it all works out nice for you.
    One LAST thing though - run some carb/fuel injector cleaner in the fuel tank, as you might need the carb cleaned out. Worst case is the float needs replacing in the carb.
    Another thought that just crossed my mind is maybe an electrical component is getting hot and shorting itself out after it reaches a certain temp, and once it cools off makes it ok again. I would have to inspect it and look it over carefully to trouble shoot it and get a final answer though.
Cub Cadet lawn tractor with Courage engine-sputters and dies after gets hot. Might run 45 min. or only 5 min
An engine that splutters and dies generally indicates a fuel delivery problem. I'd do the simple things first - change the fuel filter, check for collapsed fuel hoses, use a "complete fuel system" cleaner additive and check for a blocked breather in the fuel cap/tank. The latter is the easiest to try to fix (temporarily); just run with the fuel filler cap slightly loose and see if the problem goes away.
Nov 12, 2017 | Cub Cadet Garden
2008 cub cadet rzt 50 run for 20 min than dies while mowing put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines clear
When it stalls out did you check the spark? I suspect the engine is losing spark due to an ignition system failure.
May 17, 2017 | Cars & Trucks
I have a Cub Cadet Model 364 with a 18 H.P Briggs & Stratton motor. It runs fine for about 20 minutes. Than starts hesitating. Like the motor wants to stall out. Help!
Firstly, try to run the engine without cap on the fuel tank. If it stays running well, clean out the ventilation hole in the fuel cap ( or replace the fuel cap ).
Check for dirt in the fuel tank, fuel tank connections, hose, strainer, filter. Clean everything!
Check if you still have sparks when the engine stopped from itself.
Check if you still have compression when engine has stopped from itself ( valve settings too close )
Sep 28, 2016 | Cub Cadet Garden
Loses power while mowing
that wont cause your mower problem i think you have a dirty carb and fuel filter clean the fuel tank to put new gas from clean can in but to check charg system get voltmeter start engine let it run un hook positve side of battery put the red led of voltmeter on positive side and the black led to the negative side of battery and see how many volts produce 12 to 13.5 good below that replace regulator above that replace regulator
Jun 18, 2013 | Cub Cadet Garden
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
The mower is a cub cadet it usually runs fine until warm and will die start idling up and down and then die every now and then pop like back firing.it will start right back if you lift the choke i changed...
I had the same problem , found out it was the coil was getting hot. I replaced the coil which was not hard , remove 2 screws an unhook 2 wires. You have to get the coil from a dealer , in my area anyway. Hope this helped.
Apr 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,468 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
