How do I set audio so that it is in sync with the picture model no l65f3500fds ?
How do i tune my tcl tv model no. l65f3500fds
Press the mene and start seach channel.
Mar 17, 2017 | Televison & Video
Why do i have lip sync problems between two brand new panasonic items ?
There may be a audio offset setting on receiver, add or subtract a few milliseconds. Its not the cable
Sep 02, 2015 | Yamaha Audio Players & Recorders
Having trouble syncing audio with my new led tv. I run audio thru a sony receiver model str-dg520. Where do I find the settings to make it sync?
Normally you would to the TV settings under audio you would have to disable the tv audio and point it to your receiver I assume you have a surround sound. Make sure you are also using the right audio cable RCA or digital optic cable
Oct 24, 2013 | Yamaha Rx-v465/rxv465 Home Theater...
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Just wondering if the audio out of sync has been fixed on the newer sets
The was an audio lipsync error with some of the sets released back in 2008 but LG released a firmware update to fix the issue.
It was caused by a slow algorithm that was unable to decode video as the same rate as audio that lead to the audio being out of sync but all of the older models can be fixed via a firmware update that can be done by a USB memory stick. All the newer models were released with a faster algorithm and do not have this issue.
Oct 09, 2009 | LG 47LH40 47 in. LCD HDTV
The audio and video are not in sync
Are the movies you're watching store purchased DVDs? Sometimes with downloaded movies, the audio and video are just out of sync.
If they're store bought, it's possible that you've got a delay set in your receiver. Consult your receiver's operating manual to see if there's a "delay" option.
It's also possible that you're hearing that delay in the TV speakers.
If you've got the audio coming through the receiver AND the tv, you'll hear a slight delay when the audio's traveling from the DVD player to the television itself. This could happen "sometimes", if the tv volume is on, and not happen when the tv volume is off.
Mar 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Optical output on tv through dvd home cinema out of sync
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650, everyone suggested adjusting the delay time on my AV amp but unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then turn the TV back on again. This will get you into the secret Service Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for the internal speakers of 100ms but for some reason this is not set for the external output so all you need do is dial in a 100ms delay there and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other standard menu settings are lost and the screen will be set to dynamic for some reason so you have to go through and change everything back after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
Feb 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Scrambled Picture (Vertical Sync) Mitsubish VS6883
Im looking for an owners manual for a Model VS683R Mitisubichi
TV anyone know where I can get one copied or buy one??? thanks Grant please e-mail me at WGA@aol.com
Oct 21, 2007 | Televison & Video
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
