Question about SWANN Sw331-pr6 Ptz Outdoor Dome Camera
Why does my swann PTZ camera only proceed with half of test when powered on?
I have to 4 standard bullet cctv cameras 2 are working to are not can it be in setting
Hello George Wolfe,
Absolutely... but only one way to find out (go commando).
I've got very impressed by a lady that was highly dissatisfied by the color presentation from her SWANN PTZ (smoked dome) many years ago...
Said she had attempted to work with TECHNICAL SUPPORT to adjust color but remained UNSATISFIED with the color...
She wrote on AMAZON... That she just went "COMMANDO"
and did it all herself and was really pleased with her results...
(Jealous... and still no idea what commando was).
Probably a decade later MY DARLING wife was trying to spin one of our cameras... and blacked out OUR front PTZ
(which has always had pretty drab color)...
Then the little darling WENT COMMANDO... (women are awesome smart)... Stepped into the set-up menu
mid set all the contrast, bright & colors... and tuned everything to exactly match the UN-SMOKED fixed focus cameras...
Long and the short of this STORY... I asked her how... she said one camera had a setting tab... the other had a gear-wheel. She clicked on that... and the rest was fined tuning CAMERA HISTORY.
Get into the settings of your "working" cameras...
Check out your settings (night & day)... THEN...
Takes notes and check out your "DARK" cameras.
If you cannot pull out a picture by re-setting these
basic camera settings: all to the mid-range... then tweeking the color settings until you are DELIGHTED with your picture
Take plenty of notes or scree shots to
TRACK YOUR CHANGES... If there is anything that is still working... this is the way to get them back.
ELSE
Get yourself some NEW working cameras.
Oct 25, 2016 | Video Surveillancer P2P Plug and Play PLC...
My swann 8-camera system, each night goes into the "no video Mode" each night and comes back on in the daylight.
It's going into ir sound like you are not supplying enough power to the cameras or you might have a timer on you system
Oct 11, 2016 | SWANN H264 8 Channel Dvr W500 Gb Hard...
I have 4 cameras i was trying to play back a recorded time on camera 1 and it got stuck rewinding and after that 3 of my cameras are not clear.
Power the unit right off and disconnect it from the mains supply. count to 10 and plug it back in. Have you physically checked the domes on the three unclear cameras for condensation?
Aug 14, 2015 | SWANN PRO-751 PTZ Dome Camera with 700TVL...
What does start cruise mean ?
Start cruise is a feature of PTZ cameras ( pan, tilt , zoom ) where you can program them to move to a specific pattern.
Jan 12, 2014 | SWANN Home Security
Replace camera on swann system
Yes it is not a complicated procedure, involves just disconnecting the power and video cables and remove the screws of the old cameras.
Jan 03, 2014 | SWANN Security Swa43-d1c2 - Swann Secu...
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
Spin out of control
Reset the power to the camera and test first.
If it worked before you may have a wiring fault... or if it is new or someone tampered with it, the baud rate settings or protocol setting might have changed.
Apr 03, 2012 | Pelco CONTROLLER MATRIX- PTZ CONTROL
My SD HC 32GB card will not auto delete on Swann ADW-400 security system.
Same problem with mine. Sent it back to shop, now testing the second one.
I have emailed Swann regarding this problem and all they say is "send it back" to point of purchase.
Apr 24, 2011 | SWANN Adw-400 Video Surveillance System...
I can't remove numbers that appears in screen when i use a Samsung PTZ camera. Can you help me?
sounds like you are seeing a display generated from the PTZ camera itself. can you access the camera's menu?
Jul 20, 2009 | Samsung SADT-100PM POLE MOUNT ADAPTER FOR...
SWANN Sw331-pr6 Ptz Outdoor Dome Camera Logo
27 people viewed this question
Top SWANN Home Security Experts
Electro Med Services...
L Pfaff
L Pfaff
Da Doc
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
