Legend 42'' LCD (LEC-4227) Problem
I have a Legend 42'' LCD 1080P HDTV (LEC-4227) that will not turn on.
Here are the symptoms:
I can turn the TV on with the remote control or TV power button, but there is no picture or sound at all - the screen is completely dark. The power LED changes color which is the only sign of life.
After I turn the TV on, it cannot be turned off using either the remote control or power button on the TV.
I am not the original owner, and from what the previous owner tells me, they had a problem with a black box rectangle ''menu'' popping up over top of the picture sporadically in the months leading up to the no-audio/video problem.
I temporarily disconnected power wires to some of the internal components like buffer boards, etc to isolate the problem but it seems that the problem exists even though I only have the power supply and the ''logic'' board (a main circuit board more or less in the middle of the TV). I can only assume that the problem is in the power supply board or the ''logic'' board, but I don't know how to proceed.
Please help me and the others with this problem.
I am NOT interested in answers like ''take it to a shop'' or ''buy a new TV''. I would like to hear from someone who can tell me what board is the problem, and possibly how to troubleshoot at the component-level.
Thank you.
  • umkwiatk Jul 09, 2010
    As a follow up to this problem, the Power supply is NOT the problem. Also, this TV is essentially the same as a Polaroid FLM-4201 since they are both made by PRIMA.
    Diagnosis:
    I removed the tin shield from the circuit board with VGA and HDMI inputs. After using a heat gun (or a hair dryer) on a medium setting in different areas of that board, I noticed that the TV would turn on and function normally if I heated up the largest BGA (ball grid array) surface mount chip on that board...
    After the chip/board would cool down, the problem would present itself again. This symptom is very repeatable so I found out that this board was the problem... On one occasion, the TV worked properly except that the backlight would turn on or off intermittently... Same reason. Heating the large IC again resolved the problem temporarily... Therefore it seems to me that this board may be the cause of multiple symptoms of failure on this TV.
    The board can probably be replaced by someone who does BGA reflow or BGA re-balling, but you can probably find a refurbished PCB board on Chinese auction websites like taobao.com for about $120USD shipped.
    Hope this helps anyone looking for this info...
    Take Care.
  • SushiX Jan 29, 2012
    I also have the exact same TV. No power on, but LED turns blue. It took awhile to get the back cover off. I inspected the Power Supply Board. No faulty Caps. Took of the shield from the HDMI / VGA Board, inspected for faulty Caps...None. Did the same for the Component/ Composite Board...Nothing. A more detailed step by step, troubleshooter would be helpful and see which Cap has failed or other problem that I am aware.
  • 3 Answers
Same problem,i guess it's a logic board problem,bad software, now I try to change software,I'll write later
Posted on May 03, 2010
  • djmusic Nov 18, 2010
    the problem is inside th vga hdmi board ,i have repaired 2 of these units the 37 inch version and found a bad 100 mf 10 v capacitor that is bad. i little bit of soldering/de soldering skill is needed .
    cost of cap 0 dollars got it from old radio.
    ernie
Lg 42 no power
If its dead and no sound what so ever its usually the power board and if so you can usually get replacement boards by contacting the people over at
www.tvrepairworld.com if its not listed they most likely still have it and you can check by hitting the contact us button on their website and letting them know your model number and symptoms and a tech for your model will respond quickly to your problem for free as long as you include your model number and symptoms of the set.
Aug 04, 2012 | LG 42LC2D 42 in. LCD HDTV
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
We have an LG 42lb1dr 42" HDTV LCD TV and all of a
The issue is the main unit board. You can go to www.shopjimmy.com or www.orlandolcd.com they carry good working parts at a good price.
Thank you
Nov 05, 2010 | LG 42LG50 42 in. LCD HDTV
I have a Toshiba Regza 42 inch LCD flat screen tv. Sometimes when changing channels the scrren turns green. There is still sound. The only way to bring the picture back is to turn the tv and dvr off and...
I suggest you do firmware update first, then you can use another source such as a DVD plug in to the same HDMI input when the problem appear, to make sure where is the problem, if it is the on the TV, replace the main board.
Part # 75012465 cost approx $300.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
May 02, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Legend TV wont turn on
Martin! plasma displays cannot and shouldn't be repaired once dead. move on!!!!!!!!!!!
May 08, 2009 | NEC PlasmaSync 42MP2 42 in. Television
Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Nov 19, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
968 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
