Question about Cell Phones
Carrier OTA 15.5 MSID 0000002845 PRL 31001 ERI 1
Whats that mean in carrier section of an iphone 4s?
SOURCE: iphone sim card problem
i put the sim card into iphone is dont work
Posted on Sep 13, 2008
SOURCE: cect p168 iphone clone
CECT P168 Internet and MMS Settings that work | Email Info | Java Info Options bt_down_arrow.gif georgetaylor
New User
My Device: HP 6315
Message 1 of 30
Viewed 28,849 times
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Email will not work with any server that requires smtp authentication (which is pretty much all of them here)
Posted on Oct 26, 2008
  • 32 Answers
SOURCE: iphone not picking up signal from carrier
If you can do a full restore back to factory settings (re-locked? I don't know if you can even re-lock it... lol.. I haven't unlocked mine) and see if that works. If not, you may have an issue with the antenna/receiver unit in the phone. Apple should be able to verify the issue.
Posted on Jan 08, 2009
ipodslinger
  • 688 Answers
SOURCE: Iphone 3g 8gb Officially unlocked sim error problem
the new sim card is connected with having an iphone account. when you say it is officially unlocked.
does this mean that AT&T unlocked your phone?
what i think your saying is that if you have 2 sim cards, one that is in use and the other is a spare you cannot use both. at the same time.
the sims are standalone, to use a spare sim it has to be activated by the carrier, thus disabling your original sim.
when you change sims you will need to reboot the phone that will not change.
Posted on May 22, 2009
SOURCE: Apple iPhone Locked
my iphone locked cause the software tryed to upgrade some one help me
Posted on Jul 27, 2009
How can I turn off the busy signal on my phone?
Check your iPhone settings
  1. Turn airplane mode on and off. Tap Settings > Enable Airplane Mode, wait five seconds, then turn airplane mode off.
  2. Check your Do Not Disturb settings. Tap Settings > Do Not Disturb.
  3. Check for any blocked phone numbers. Tap Settings > Phone > Blocked.
  4. See if Call Forwarding is turned on. Tap Settings > Phone > Call Forwarding.
Update your software
  1. Check for a carrier settings update.
  2. Check for an iOS software update. Some updates might require a Wi-Fi connection.
Remove and reinsert your SIM card If your iPhone has a SIM card, remove the SIM card, then reinsert it. Update your Preferred Roaming List (PRL) The PRL determines the cellular towers that your iPhone uses for cell service and selects those with the best signal strength.
  • If you're on the Verizon network, dial *228 and select option 2.
  • If you're on the Sprint network, dial ##873283#.
Contact your carrier When you contact your carrier, check the following:
  • Your account is set up to use your iPhone.
  • There aren't any localized service outages.
  • Your account doesn't have a billing-related block.
  • Your calls don't have errors on the carrier system.
Check your network settings
  1. Reset your network settings. Tap Settings > General > Reset > Reset Network Settings. This will erase all current saved settings, including Wi-Fi passwords, preferred networks, and VPN settings.
  2. Try to make or receive calls in another location.
  3. Switch to a different network band. Tap Settings > Cellular and turn off Enable LTE, 4G, or 3G (this option will depend on your carrier and device model).
Still can't make or receive calls? If you still can't make or receive calls, restore your iPhone as new.If restoring doesn't fix the issue, contact Apple Support or take your iPhone to an Apple Retail Store or Authorized Service Provider.
Mar 14, 2016 | Panasonic Lands Phones
How do i bypass a icloud activation screen on ipad 2 reported lost
Unlock Timeframe: 7-15 working days
iPhone Carrier iCloud Activation (Clean Only) Choose an option... iCloud Activation (Clean Only) iPhone Model Choose an option... Choose an option... iPhone 6 Plus iPhone 6 iPhone 5S iPhone 5C iPhone 5 iPhone 4S iPhone 4 iPad Clear selection
IMEI: Please add IMEI number which contains 15 characters only
Feb 22, 2015 | Apple iPad Tablets & eReaders
Iphone4s Unlock phone From carrier
What's your current locked carrier?
You can unlock your phone from network lock by Remote unlocking method.It's one of the best and safe way to unlock your iPhone without jailbreaking.If you are interested in this method visit OnlineGSMUnlock.com Here you can unlock your iPhone 4s at low cost.
Dec 07, 2014 | Cell Phones
How do i unlock iphone 4s
Contact the carrier that the iPhone is locked to. Do no call Apple because they cannot unlock iPhones.
http://support.apple.com/en-us/HT201328
Oct 10, 2014 | Apple iPhone 4S
Unlocking an i phone 4
Locked iPhones can only be unlocked by the carrier they are locked to. Apple will not get involved. You need to contact he carrier and negotiate unlocking with them.
Jan 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
HOW DO I UNLOCK THE IPHONE 4/4S TO ALL NETWORKS
Hi, it's possible with the following service that provides an official carrier authorized unlocking for iPhones: http://www.fastgsm.com/en/apple/apple/iphone-4s/unlock/country-network
Dec 11, 2012 | Apple iPhone 4S
Unlock iPhone 4s to AT&T network
hi ,you need to factory unlock your phone...please post your IMEI number so we can see if what is the carrier...you pay a little bit money to unlock it..
Oct 01, 2012 | Cell Phones
How to activate iphone 3gs
Simply insert your SIM card into your iPhone (with respective carrier IE AT&T in an AT&T iPhone or activate a Verizon iPhone 4/4S on Verizon with a clean ESN). You may need to contact your respective carrier to validate a data plan in order for the iPhone to function properly with data and visual voicemail.
Dec 06, 2011 | Apple iPhone 3G
Switching back to verizon from metro with same phone
all you need is lg downloader or lgnpst software you can google those and a verizon prl. and once you have either of those softwares and the drivers for your phone is installed u can get that from here:http://www.humpa.com/vzw/. and a usb cable for your phone to connect it to your computer and where it says prl/eri u can load the verizon prl and write it to your phone. you will find it in the link i have given. dont look under the part for lg voyager but instead look under the section for LG-VX8500 Chocolate PRL - PRL.
  • LG-VX8500 Chocolate ERI - ERI.bin zip - You should only need this if you screwed up! hopefully this helps. good luck
  • Jul 08, 2009 | LG VOYAGER VX10000 Cellular Phone
    Cell Phones Logo
    15 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
