Question about Eagle C5160v1 - Single Stage - 5hp 60 Gallon Air Compressor 18.5 Cfm
What grade of oil do air compessors use - Eagle C5160v1 - Single Stage - 5hp 60 Gallon Air Compressor 18.5 Cfm
    New Friend:
Best is call Pure mineral oil 100 aviation oil. actually 50 wt.
it is for piston airplane engines. My 5 h.p. powermate Black Max is 20 years old...still full strength and gets hard use... I have changed the oil every 4 months since I have had it.
Posted on Jan 23, 2015
  • 32 Answers
Iso 32 // 30wt. compressor oil, or no additive mineral oil, never use automotive oil in a air compressor
Posted on Jan 22, 2015
Knocking noise
2545 is a piston compessor if so you've got a busted rod on one of your cylinders , this will fail catastrofic and break out side of compessor but if caught early can still be rebuilt with a few new parts
Mar 18, 2014 | Ingersoll Rand 2545 pump,air compressor
Air hissing out of crankcase vent when not running also oil coming out of vent
You have a serious ring wear problem . The crank case never is pressurised.
Feb 02, 2013 | Air Tools & Compressors
Toyota ipsum 2001
The air compressor is on that drive belt if you are getting a bad noise when the air is turned on you probaly need to replace the unit. You can try adding air compessor oil to the system and it may help.
Sep 09, 2012 | 2004 Toyota Camry
2002 toyota echo air conditioning oil capacity
Toyoa air compessors use between 7 and 8.5 ozs.
Apr 22, 2012 | 2002 Toyota ECHO
What kind of oil do i need for a craftman 1 hp 3 gal 125 psi compressor m/ n 921 153101?..
For warm climate, use 30wt non detergent oil (lowest price $3). Med priced oil ($5), use compessor oil sold at Lowes or any major center store including Wal Mart. Compressor oil is special blend for higher temperature range (continuous use). High price oil, synthetic compressor oil works for heavy duty use under severe conditions (also sold at major lumber centers, cost about $8~18).
For lite duty, any oil that you have handy will work fine (check oil before every use). Good luck
Oct 03, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
What grade oil do I use to change out on my Chicago Pneumatic RPC-561VNS? The manual says a compressor grade non-deturgent oil should be used, but does no specify a grade.
Hi and welcome to FixYa, I am Kelly.
Compressor grade oils are basically SAE30 W oil. Read this:
Rol-Air OILCOMP30W34C Air Compressor Pump Oil - 30W Quart features ,
Specially engineered and tested to match the requirements of Rol-Air air
compressors , Provides superior rust and corrosion protection.
I.e SAE 30W oil / the same thing you would use in an older lawn mower engine or generator.
What they don't tell you is because they have re-labeled the 30W oil to OILCOMP30W they can charge you big time for SAE 30W oil. The only difference is the label.
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Chicago Pneumatic 60Gallon TwoStage Air...
How much oil compessor do i need to put in the new compessor for a lincoln 2001, and also how much 134a do i need to put in the compressor.
Use your dip stick. My Snapon a/c repair kit came with two dip sticks. There might even be more now. any auto parts store will have the oil in stock. When i ask the napa store to bring me some, it came in a qt bottle. With oz marks on the side. I sure hope i was of some help to you. Sawdust
Aug 13, 2009 | 2001 Lincoln LS
Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Apr 25, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Eagle C5160v1 - Single Stage - 5hp 60 Gallon Air Compressor 18.5 Cfm Logo
180 people viewed this question
Top Eagle Air Tools & Compressors Experts
John Trevino
Bill Boyd
Steve Pack
Steve Pack
Are you an Eagle Air Tool and Compressor Expert? Answer questions, earn points and help others
