Question about Canon SELPHY Office Equipment & Supplies
Hi, I just wanted to know if there is something I can do from my end that's Fixable before having my selphy cp900 through a local canon service center. I have been using the selphy CP900 for almost 2 years now, superb performance and very reliable until last week. I got an error message saying that a sheet got jammed in the feed and so I checked and indeed there was 1 canon paper that got stuck so I removed it and following the instructions on the screen I had to reboot the unit and insert the cartridge again into the paper feed. After the boot upI insertd the paper cartridge, Until I got another error saying that the ink cassette is empty. Again, following the instructions on the display it asked me to remove the ink casette etc. and so I had the unit rebooted I got a fresh cassette inserted it into the unit but I'm still getting the same error. please help I don't know what to do
SOURCE: paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Posted on Oct 28, 2007
SOURCE: Canon Pixma MP610 CARTRIDGE PROBLEM
HI. Try holding the reset button for 6 seconds to overide the error. This may dissable the chip so it won't report but will allow you to keep printing. Simply check the ink tanks visually.
Refilling will give the same error too, again dissable the error.
Cheers Bob Monk (ink manufacturer magink@froggy.com.au)
Posted on Jun 02, 2008
SOURCE: I am printing on a
Check "Printer Properties" so that the cartridge is set to color if E-Pxx cardridge is mounted and set to B/W if E-PxxBW cardridge is mounted...(xx stands for number of postcards) // Kjell.sundling@hotmail.com
Posted on Nov 08, 2008
  • 52 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Posted on Jan 23, 2009
  • 298 Answers
SOURCE: Paper Jam Issue with the HP Deskjet 5440
Clean the contacts on the HP Cartridge. I've had the same error before and i switched it to a fresh new cartridge.. works fine ever since. THen i decided to switch back to the old cartridge, same error as you but i cleaned the contacts on the cartridge, works for a while but done after a week. Problem is that the ribbon circuit is rusted and the printer doesnt recognize the ink anymore.
Also make sure you both have the ink cartridges in place. Make sure it is seated properly inside.
hope this helps!
-levibit-
Posted on Mar 20, 2009
My selphy going through the motions of printing but nothing is on the paper
100 pics is a lot of ink
have you replaced the cartridges to fix the problem
Oct 29, 2016 | Office Equipment & Supplies
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Printer say's that paper is not compatible
then try a different size or layout landscape instead of portrait
Mar 13, 2015 | Canon Selphy CP900
Paper size
It looks likes the unit comes with a Paper Cassette PCP-CP400 which is for Postcard Size paper. You should be able to reuse the Cassette for any postcard size paper. If you want to use L Size or Card Size paper you will likely need to purchase an additional cassette for that size.
Jan 01, 2013 | Office Equipment & Supplies
My printer is only 5weeks old / installed end of March and i have this error message on the display screen 6C10 I have tried ti turn the printer off and back on again but the error still occurres. Do...
This error is caused when the ink absorber has got full and needs to be replaced.
This is something you can get done by a local service centre or a Canon service centre.
Andy
May 02, 2011 | Canon MP640 All-In-One InkJet Printer
How i can clean my printer selphy ES30 also how to solve an error paper jam
For Paper jam:
• Press
(BACK) to eject the paper.
If the paper is not ejected, turn the power off and turn it on again. If the printer fails to eject the paper, contact a Canon Customer Support center for assistance. Other solution here: http://canoncanada.custhelp.com/app/answers/detail/a_id/10212/~/error-messages-displayed-on-the-screen-(selphy-es30) For cleaning try local canon provider.
Dec 12, 2010 | Canon SELPHY ES30 Thermal Photo Printer
Selphy DS 810. Shows error code 5100. I want to
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Only gave it a go
All The Best: Pineworks
Nov 19, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Canon selphy ds810 error code
5C00 says that the purge unit is not cycling properly. It's the cleaning unit where the printhead parks. If you can't see something caught in there, it's probably a shop repair...
Jul 27, 2009 | Canon SELPHY DS810 InkJet Photo Printer
User manual required
Hi there here is the link just click it or copy and paste it to your browser http://www.generalmanual.com/Printers/Canon-SELPHY-ES2-Compact-Photo-Printer.htm
please rate me thanks have a nice day
Jan 03, 2009 | Canon SELPHY ES2 Printer
Printing marks
I had issues like this, and changed to thinner paper. That solved my problem
Jan 01, 2008 | Canon Selphy CP510 Thermal Photo Printer
44 people viewed this question
old marine
old marine
